Complete Disc Brake Conv Kits!
Big D's 69
Re: re: Complete Disc Brake Conv Kits!
Post by Big D's 69 »
bigdaveb12 wrote:I'm in the same boat with my '67. I found a company that sells a '65 - '70 conversion kit that includes the calipers, rotors, brackets, hoses seals, power brake booster, master cylinder, proportioning valve, and all the misc. stuff. I called them and they quoted $790 for the kit. Take a look and see what you think:
http://www.abspowerbrake.com/AbsCatalogPag-088.jpg
Well I just emailed them to get the details. Man from the way it sounds that is the way to go without having to change your spindles. That takes a ton of work out of it. Thanks for the info.
snake
Post by snake »
I've often wondered why there weren't disk brake conversion kits that use the stock drum brake spindles for the twin I-beam trucks. That's no different than what has been offered for the older single I-beam axle trucks for quite some time......
Maybe they have been available for awhile but I just didn't know where???
flyboy2610
Post by flyboy2610 »
snake wrote:I've often wondered why there weren't disk brake conversion kits that use the stock drum brake spindles for the twin I-beam trucks. That's no different than what has been offered for the older single I-beam axle trucks for quite some time......
LMC Truck has them available for F100's.
http://www.lmctruck.com/
dotcentral
Post by dotcentral »
I wouldn't be suprised if there is a car or truck that has disc brakes that would fit on our spindles. But no one has ever mentioned it so maybe not.
splavin90
Post by splavin90 »
i saw it on fleabay. all new hardware, new everything. pricey
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
