69 f-100 short bed coyote swap now Project Howlin'
- BrockGrimes
Re: 69 f-100 short bed coyote swap now Project Howlin'
Progress?
If it's not broke, MOD IT!
1972 F100 short wheel base, 302, C6, 9"
- 48prerunner
Not much progress the cold weather slowing me down by time i get woodstove going and garage above 40* its like 7pm that and plowing snow. But I did finish the driverside exhaust and cut hole in rad support for cold air intake. also mounted res for power steering and made lines
![Image](http://i325.photobucket.com/albums/k367/ford1969/rough%20hole%20back_zps14inepyo.jpg)
rough hole
![Image](http://i325.photobucket.com/albums/k367/ford1969/rough%20hole_zpsxlum3w5j.jpg)
finished rolled edges to look like a factory stamped hole
![Image](http://i325.photobucket.com/albums/k367/ford1969/finished%20air%20duct_zpsowm2u7eo.jpg)
rough hole
- 48prerunner
- 48prerunner
So finally warmed up and made a little progress. Have the boxing plates welded in, finalized the motor mounts and the two tubular cross-members I made. Put the clutch and pressure plate in along with the proper Ford racing bellhousing bolts. I used a gear drive starter off an expedition and had to clearance the stock crown vic motor mount a little for it to fit in.
- 48prerunner
- 48prerunner
Ran all the fuel lines with returns used Nylon lines with push connectors works really nice. Getting closer to start up.
Post some more info on your fuel line. Pics if possible. I am about to dive into this for mine.
Barry
Barry
- 48prerunner
- 48prerunner
- 48prerunner
good link on fuse and alt wire
http://www.squarebirds.org/vbulletin/sh ... hp?t=13542
- 48prerunner
ENGINE and electrical all hooked up, engine turned over with the starter for the first TIME! Hopefully will be starting it by wendsday ![Woohoo! :woohoo:](./images/smilies/icon_woohoo.gif)
- 48prerunner
getting closer, just need to put fluid in the tranny. gas in the tank, and water in the cooling system, and double check everything 400 times then just turn the key I hope.
- 48prerunner
![Image](http://i325.photobucket.com/albums/k367/ford1969/mufflers_zpstwwvhjvo.jpg)
Have most of the exhaust done, with 3" pipes didn't have room to go over the diff, so will be out in front of rear tires. Is all stainless including the welds. Magnaflow stainless mufflers, Stock 2013 mustang h pipe and stainless cat deletes. I just have to figure if I'm going to come out the bed side or try and hide it in front of rear wheel.
- 48prerunner
- 48prerunner
