My '69 2wd Crew Cab Project
- FormerMarine1981
Re: My '69 2wd Crew Cab Project
Man that looks great... Should have it back on the road any day now.
Installed the rear driver door and started on putting the interior back together. Im waiting for the passenger side front door panel to dry so I thought I would update.
Also got the seats put in, but they are the wrong color. I've had good luck with vynl and fabric dye from VHT, so when the cans show up in the mail Ill pull them back out and dye them black.
Also took a closer look at the rear door panels and they are rusted out bad, im going to have to make a run to the junkyard and cut down some standard cab door panels to fit.
But for now Im just going to enjoy driving it!
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- cloudwalker
The truck looks great!
Are you going to be putting a rubber OE floor mat or something different?
cloudwalker
cloudwalker
“It’s not the critic that counts, not the man who points out how the strong man stumbles, or where the doer of deeds could have done better. The credit belongs to the man who is actually in the arena.” Teddy Roosevelt
I sprayed in a bedliner coating on the whole floor, even up under the dash. I dont plan on putting any carpet down its a about 1/8" thick and it insulates ok, best part is when it needs to be cleaned out I just get the garden hose and rinse off the floor.
I do plan to install some fiberglass insulation in the doors, back cab wall and the roof before i install the headliner.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
took the truck on a trash run today and washed it afterwards, took some pics at the local harbor.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- dantheman71
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
Awesome!
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
55F100
- Ranchero50
That's a lot of truck, how does it fit in most parking lot spaces?
Jamie
Jamie
Thanks guys
Well as far as parking goes it doesnt fit!
In a normal sized space it sicks out about 3 feet, and three point turns are required when turning around or parking.
Im going to be towing a 28' enclosed car trailer when i do my cummins swap so that should make things interesting. But it cant be worse than driving the semi with a 53 footer. Driving it now reminds me of driving the semi bobtail (without the trailer) brings back memories in a way.
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- Ranchero50
That's about what I figured. I built a friend a '84 Chevy 3500 crew cab rollback and it fills two normal parking spaces but he usually takes up four so he can get out... I was looking at my '70 F350 trying to figure out what is the turning radius limit because it looks like my spindles don't hit the stops. I wonder if we couldn't get a longer steer box arm to get more throw out of it?
BTW, I'm doing the Cummins 2wd thing now.
Jamie
Jamie
[/quote]
Any chance you have an extra hubcap or two laying around from your parts truck?? I'm getting ready to polish and restore a set I picked up last month, but one of them has a decent dent in it. I'm not too far south from you near Gig Harbor...
Your truck looks great, you do fantastic metal work!
Joe.
Well its been awhile since I last checked in, since that time Ive been driving the hell out of this thing and putting it to work! I havnt done anything else to the truck yet interior wise, but a few accessories here and there, and I still need to get a bedliner sprayed in when I can find some time to drop it off. I've put around 4-5000 miles on the truck since I got it back on the road, but Im averaging around 6-8 mpg which kinda takes away the joy in driving it.
Since the beginning of this project I planned to eventually drop in a 6bt and that time has finally come!
Today I picked up a donor truck for $1600 its an 89 non intercooled 3 speed auto, The engine's milage is questionable though the seller claims 164,000 but Im thinking 264 or 364. It doesnt smoke, no weird noises and it fires right up trans shifts through all the gears but is a little sluggish in 3rd. So I definatley plan on rebuilding the 727 and doing a few upgrades. As far as the engine goes from the looks of the pump I dont think its been tampered with and I plan on leaving it that way, I want mpg's and a little power to boot! I will definatley run a staight pipe though the sound this motor makes is music to my ears!
Dan
'69 F350 Crew Cab
'69 F350 Crew Cab
- The Big Bear
Awesome Job man, it is great when yo wee one put back together and back on the road. Way to many times things are given up on and not finished. Enjoy and drive it now!!
Be grateful for every day
- FormerMarine1981
Hard to believe it's the same truck from page 1
- The Big Bear
Great work I am using a lot of your photos and leads on your project and it awesome to see it on the road. It looks huge in the pictures I keep telling myself mine is ONLY a short bed!!! Looks awesome!
