68 CS Project: update 4/16/09
re: 68 CS Project: update 4/16/08
Man that looks great, I think you've given me the kick in the rear I needed to get back to working on my 70. The pics and detailed posts are very helpful and encouraging... thanks for sharing!
1970 F250 Camper Special
"Its no coincidence that man's best friend can't talk."
- kaptnkaos
Thanks Guys,
Glad to be able to help...
That sounds great rjewkes... zip here is 98541
Hey I got a question... How do ya tell which horn is which ???
They both look alike to me...
KaptnKA
S
KaptnKA
- rjewkes
one says LO on it the other says HI.
fuelly.com
fuelly.com
- kaptnkaos
for real... are ya pullin' my leg ???
I'll have ta check the one I took off this evening...
I'm gonna try diassembling it to see what's inside...
KaptnKA
S
KaptnKA
- rjewkes
No leggpulling just around the contact for the harness.
fuelly.com
fuelly.com
- kaptnkaos
re: 68 CS Project: update 5/6/08
Hey guys,
It's been a little while since Ive got to do anything on the '68 CS...
This evening, I finally got a chance to work on the new fuse block.
Here's a couple pics of the new fuse block before installation.
The finished size is 3.5 x 5 inches.
I'm going to have to fabricate a mounting plate that will mount to the original holes, with holes that match the new block so it can be mounted in the original place.
I'm pretty happy about how it turned out so far...
Here's a couple pf pics...
Disassembled gang fuse block
Revamped & reassembled
click on pics to enlarge
I started with a 10 fuse Buss gang fuse block.
I dissasembled it, then cut the power distribution tree in two pieces.
I couldn't figure out an easy way to attach a hot wire to the second piece.
I had another fuse block that I'd gotten for the bus.
I cut the tree of the second block to fit the first block.
Then reassembled the block.
I drilled out the holes to mount the single fuse hoders and soldered them in place.
Then used a zip tie to secure the other end. now...
One side supplies 4 fused circuits with power from the ignition switch.
(circuit # 297)
The 2nd side is a direct feed from the battery to 6 fused circuits.
(this is for new circuits like the spot light, stereo & amp, etc)
The other power distribution block feeds up to 12 unfused circuits with power from the light switch. (circuit #37)
The two separate fuse holders are for circuits #54 (cigar ltr / dome light) and circuit # 383 (e.flasher / brake lights)
The remaining in line fuseholder is for circuit # 19 going to the instrument panel.
That should eliminate the poor connections at the fuse block and add the extra circuits I needed.
KaptnKA
S
(circuit # 297)
KaptnKA
- Thunderfoot
Aha, you figured out how to get more power feed circuits out of that fuse block, good deal
and that reminds me I need to work on that fuse block schematic
I'll get to it sometime soon...
Shayne
- JWW
Re: 68 CS Project: update 4/16/09
JWW
1967 F100 Ranger, Auto, 240ci
2004 F150 Crew Cab
2004 F150 Crew Cab
