ORIGINAL TIRE SIZE FOR A F-100?
- 71 LONG BED
DOES ANYONE KNOW WHAT THE STOCK TIRE SIZE ON A F-100 WAS? I THINK IT WAS A G-78-15, OR SOMETHING. WHAT SIZE COULD I CROSS REFERENCE IT TO, SINCE THEY DON'T SIZE 'EM LIKE THAT ANYMORE. THANKS FOR ANY INFO ANYONE CAN GIVE ME.
re: ORIGINAL TIRE SIZE FOR A F-100?
I looked in my owners manual, it says the same thing, Have you tried calling a tire shop, they might know the conversion??
- 72fordjah
the stock tire size should be 215/75/R15
Alpha Numeric: G78-15
The "size designation" is a combination of one letter and four numbers and is a three-part code. The letter denotes the sidewall-to-sidewall width of the tire; the two numbers grouped with the letter refer to the height-to-width ratio; and the numbers following the dash indicate in inches the diameter of the wheel rim the tire will fit. Therefore, the above tire is "G" in width, and the sidewall height is 78% of the width. It is designed to be mounted on a 15" wheel.
i got this off a website here http://www.musclecarclub.com/library/tech/tires.shtml
scroll down that link there is a conversion chart.
- 71 LONG BED
Thanks for the info 72fordjah!!
- 71 LONG BED
Sorry f26yrn04558-72, thanks to you to! I just want to replace the HUGE tires (that rub...) with something a little more "2wheel drive" looking. I figured I would start with the stock size.
- 72fordjah
A little bit bigger than stock.. but a good size. 235/75/R15
my dad was telling me about when radials first started selling. he put a set on his old comet and he about lost control of the car when first driving it with the radials. because the car actually went were he steared it
My Truck has 215/75/15's on it. They are actually getting kind of hard to find. It had 235's on it when I bought it, they are really too wide for the stock wheels I thought it looked a little silly, but lots of folks use them because it is a common size. 225/70 is also pretty close in overall diameter.
- 71 LONG BED
