I hope this is not too stupid of a question.
My front tires are kicked in at the top causing wear on the inside of the tires.
My question is if the front springs were sagging badly, would that cause this to happen?
Thanks, Ratfink
Front end question
- ratfink
Front end question
Dennis
1968 F100 Ranger 390/ C6 (Mine again)
2008 Toyota FJ Cruiser Sandstorm
2007 3500 4X4 Dodge Cummins
Idleness is the mother of all vices.
- 390Nut
re: Front end question
Yep, that's what is going on. The I-beams can get bent, causing the same problem, but it's not as likely as the springs being worn out. It's also much more difficult to find a place that can rebend them, properly (without using heat)
Replacing the springs should straighten it out, just remember the right and left springs are different, due to the offset of the engine (not a lot of offset, but enough to make a difference).
Paul
![Image](http://img.photobucket.com/albums/v169/FrayedSanity/ford1.gif)
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!"![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
isnt it a misconception that camber causes tire wear? if its not completely off the ground, its other things (toe) that cause most of the tire wear. The part of your tire on the ground wears out just as if it was fulkly on the ground, but of course the part not touching the ground does wear, which gives it uneven wear, but i wouldnt say premature.
the toe is where all the tread is getting torn off. atleast this is how i understand it and have been told by quite a few good suspension people.
- ratfink
I thought it was the springs because I had it up on a lift last week and really gave it a good going over.
Thanks for all of the input.
Ratfink
Ratfink
Dennis
- CH3NO2
I had the same thing happen on my 68 f250. I adj. the toe-in and greased everthing good,haven't had a problem since.
Be sure to check the toe. Excessive toe out will cause the front end to squat and feather edging of the tire tread. Feel the tread on the front tires and if it is smooth side to side then likely the cause is spring sag (excessive negative camber). If you feel that the tread lugs have a higher edge then it likely a toe problem. If you need springs I found that Napa could get the ones for my '68 F-250 and maybe they could get yours too.
