ot aluminun extrusion repair
does anyone know of a way of soldering or brazing aluminun together? not trim on trucks. i know it can be done with an aluminun welder but is there any other ways? like with a propane torch and some alum rod? what kind of flux would be needed ? i'm trying to join a corner of extrusion. i don't think jb weld would adhere to it.
binder56jd
re: ot aluminun extrusion repair
Post by binder56jd »
:hmm: :dk: i'm gonna look around about that - good question
now serving #235
Leadfoot
Post by Leadfoot »
boy that sounds intresting, you know aluminum starts melting at around 1000 degrees right? you try to torch those peaces together I want to watch your face when the aluminum melts and hits the floor :lol:
you need to weld it really but magic can happen with some cold weld compounds or glue. I like duck tape looks bad and works real good. :lol: :lol: :lol:
WHAT ?
i used jb weld. the tube says it works on aluminun. so i put it on there. i hope it hold together.
Leadfoot
Post by Leadfoot »
I had good luck with that stuff man the guy that came up with that stuff needs a big pat on the back.
WHAT ?
i've had it not work at times. and other times it does work. i was reading on the jb weld site were a guy threw a rod through his block and put a bolt and washer in the hole and jb welded it. supposedly it didn't leak.
Leadfoot
Post by Leadfoot »
true but ya got ta clean the surface real good no oil or oxidation, thats the trick man did I ever learn that the hard way. :lol:
WHAT ?
Sharkdance
Post by Sharkdance »
For the aluminum repar just use pop rivets and then caulk over the rivets if there is a need to seal the joint from leaks.
As for JB Weld. That stuff is great.
I had an 87 Sportster that had decided to spit third gear out thru the bottom of the transmission case. Wasnt fun when it happened. Locked up the rear wheel at about 45mph. Left a hole in the bottom of the case about the size of a silver dollar.
After cleaning everything up, I plopped in a good amount of JB Weld and ground it smooth from the inside of the case. Replaced the busted gears and rode that bike another several thousand miles before selling it.
I know the repair worked because I saw that bike for sale again a year later and it was still running with no leaks.
Sharkdance
70 F250 2WD 360/C6
i was butt joining two pieces. i had no way of putting screws or rivets in it.
