How do you "adjust" the coil springs?
RandyBee1
Post by RandyBee1 »
I'm in the process of replacing my king pins and decided to do the radius arm bushings and the axle pivot bushings. After dropping the front end I'm now ready to bolt everything together. so.. do I put a jack under the front end and take the tension OFF the coil springs to tighten down the nut, or do I relieve all the tension on the coil spring and tighten the nut?
The nut I'm talking about is the one that attaches to the stud that connects the radius arm to the axle and hence the the coil spring
Any ideas?
Randy B.
1970F250
Post by 1970F250 »
i think (but i cant remember what i had for dinner) that i jacked mine up a little till i could get a wrench in there.
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
marz68
Post by marz68 »
That sounds just about right blue oval guru.
mcarlson11
re: How do you "adjust" the coil springs?
Post by mcarlson11 »
if you have a spring compressor, then get everything bolted up without the coils in, then add them in once its all done. I did it this way, and didnt have to hassle with the springs while I bolted everything else up.
When the going gets tough, your doing something right.
boots
Post by boots »
:hmm: I have different coil springs that you guys but I just yanked on the nut as hard as I could with the coil under the weight of the truck. Works good :D
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
:yt: thats what i did to my 93 it was loose after some supposed mechanic done something to the front end before i got it.
