Greetings all.
Am hoping for some input regarding inner fender seals. You know those tar paper like flaps at the back of the inner fenders that seal them against the firewall and supposedly seal the hood hinges from the fenderwells and keep them from rusting out?
Welp, I removed all of them from my aprons while prepping them for paint and am considering installing them without the factory seals.
Would there be an issue with dirt/water/rust without them? Has anyone else re-installed inner fender aprons without stapling new seals to them?
I haven't tried it yet. Dont know if Ill go thru with it as Im sure there would be a noticable gap between the firewall and the aprons so Im probably gonna have to buy some replacements. My old ones were hard and brittle and destroyed.
Just wanted some feedback first.
Apron seals
- Sharkdance
re: Apron seals
You mean your truck still had those on it? No clue when mine disappeared... had the truck for 6 years and they were gone when I had it.
Patrick
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
re: Apron seals
The main reason for those seals is to keep dirt/debris from dropping down inside the front fender brace, which is where front fenders typically rust out. I've coated the backside of both of my front fenders with POR-15, so I don't have to worry about those seals. But otherwise, you might want to reinstall them. They'll stop a majority of the mud and rain, and some is better than none, right?
