power sterring oil cooler hose?
- clarkent1155
Ok, I've replace the power steering gear box and now I still have leaks at or near the PS pump. There is a oil cooler that sits above the ps pump and one of the hoses to the return line is rubber, no problem to fix but the other one looks like rubber plus metal connection to the gear box. Can I just replace this part with just the rubber hose because it's a return line to the cooler and back to the ps pump?
- heep70
The hose that is just clamped you can replace with a regular hose, but the one with the fittings is a high pressure line. They offer them at the auto shops. Or take a chance and go junkyarding for one.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- clarkent1155
re: power sterring oil cooler hose?
I know there a pressure hose from the pump to the gear box which I had replaced but there one from the gear box to the cooler which appears to be a pressure hose and from the cooler to the pump is the return line which is just the rubber 3/8 hose. I wasn't sure if I replace the hose from the gear box to the cooler with just a 3/8 hose? Is there much pressure from the gear box back to the cooler anyway?
- heep70
You can replace the hose from the gear to the cooler with regular hose. It should be just clamped onto the fitting off the gear.
Greg
- clarkent1155
ok, that fine. I'll be replacing the ps pump tomarrow night with the new hose and hopefully no leaks. Thanks for the info.
