Radiator company suggestions
Ferris95
Post by Ferris95 »
Looking for a direct fit radiator for my 68 F250 camper special 390 Fe.  2WD with C6.  Not sure if I have the original radiator and it has no fan shroud (which I also want).  The core is 26 1/4w x 19 1/4 tall.  The one at LMC has plastic tanks.  I don’t want the shiny aluminum ones as I want to keep a semi-stock look under the hood.  Should I be looking for an all aluminum ones?  Or are plastic tanks ok?  Or is the old brass and copper the best bet?  Not sure who makes those anymore.  Any suggestions on good brands would be great!  Thanks.
68 F-250 Ranger Camper Special 390 FE
Retired Army
Gaslight
Re: Radiator company suggestions
Post by Gaslight »
I just recently pulled the original type radiator or of my 69 (360,C6). I had found another original radiator and had it all gone through. If you are anywhere near Ventura County I will give it to you to have rebuilt. Its in great shape and might just need a good clean. But could need a core.
Jake
1969 F100 Ranger
Mach428
Post by Mach428 »
That truck should have come with a great cooling radiator. Have yours rebuilt at a rad shop. It will still need a shroud. I added factory AC to mine and replaced the factory 5 blade fan with the same diameter 6 blade. No cooling problems whatsoever.
