Throttle Cable Setup
No tech discussion, please
flynbrianw
Post by flynbrianw »
What throttle cable/brackets is everyone using for 352fe with a 4b carb setup? I have 65 Ford F100 and I am currently running a performer intake with a Edelbrock 600cfm carb. I installed an adjustable length braided cable several years ago and due to the sharp angles between the fire wall penetration and the carb bracket the pedal is very rigid to press and had to use multiple springs to return. I have bent the throttle cable brackets slightly to change the angles and it helped but it still just doesn't look or feel right so I am considering ordering new cable/brackets. Just curious what everyone is using. Part numbers or pictures would be greatly appreciated. Thanks.
