Holy Cow! I'm still around.
No tech discussion, please
dolinick
Post by dolinick »
I had my 1968 F500 sitting for over a year becuause of bad wader pump but also i was busy drinkin or working. i'm back now. The question is what to do with my wheels and tires? It has old 7.50-20 Tube Type Load Range E Goodyear Tires on it. possibly widowmaker split rims but i don't know. One tire and tube doesn't hold air. The rest are holding 30 to 40 psi. I don't want to put moar. Not sure what they are supposed to hold. muffler split open last time i sheared the roll pin. Boom! it was a new muffler. No brakes but i bled the rear a little bit and it has some brakes now. i was lazy and sprayed a quart of boiled linseed oil mixed with one quart of mineral spirits. It is dark and shiny now but still sticky after a day. you are supposed to wipe on a thin coat i think. but i'm sure it isn't gonna hurt anything. You want pictures don't you? Fine.
my other projects are a 1992 Ford Festiva. It runs. poorly.
1983 F100 SWB 300 inline six and 3 speed manual. Does not run but I have a donor 300 inline from a 1977 ish F100.
1979 GMC C20 350 v8 4 speed granny transmission. Runs! but i removed stuff to try and replace wader pump. still taken apart and maybe a bad head gasket.
2003 F250 daily driver, six speed manual and two wheel drive, crew cab, long bed and 7.3 L Diesel baby! I feel like i missed something. nope. that is the fleet. Green, Grey, Brown, Blue and Red vehicles. F500, Festiva, F100, GMC C20 and F250 Powerstroke.
2003 7.3L F250
1968 F500 Utility Truck
dolinick
Re: Holy Cow! I'm still around.
Post by dolinick »
2003 7.3L F250
