Front disc brake bias issue ongoing … looking for ideas
ChrisB
Post by ChrisB »
I have a very obvious pill to left as though the right side is laying down. I changed the right caliper both bridge and piston assembly with typical reman and pull is still there. I am going to drive it for a while with a infrared gun along and try to make sense of what I’m seeing.
It’s as though the left front is fully functional and the right is doing maybe 25% of its share. The pads look like they’re not even bedded though the rotor friction faces are slick.
I’m inclined to think the left is normal but maybe it’s too tight. There is a bit of play/caliper movement if I grab it and shake the right, the left is firm as installed, not sure why these differences exist and above all while the front brakes are nowhere near normal in function.
What could it be? Is there residual pressure valve on these ? Left is good right is bad?
Everything has been bled twice in the last three weeks.
cep62
Re: Front disc brake bias issue ongoing … looking for ideas
Post by cep62 »
I've had the flex hose give issues before , it can look ok but have a restriction inside.
ChrisB
Post by ChrisB »
Flex hose?
I’ve got regular hard lines and steel braided hoses from last chassis point to caliper.
1972hiboy
Post by 1972hiboy »
ChrisB wrote: Sun Nov 27, 2022 4:24 am Flex hose?
That is the hose he is referring to. It is commonly called a flex hose.
If I was attacking this problem I would suspect calipers first, flex hoses second, if replacing those components and getting good brake system bleed results I would start peeking at the rear brakes too, make sure they are adjusted correctly and evenly.
Rich
Dont eat yellow snow.....
basketcase0302
Post by basketcase0302 »
=cep62
:yt: :yt: :yt: :yt: :yt: :yt:
Even a "new" hose (stainless on the outside doesn't change the softness of the rubber hose on the inside of the stainless) can be failing allowing the rubber to distort.
I'd also thrown another caliper on it as it should be holding the pad tight against the caliper.
hfdco4
Post by hfdco4 »
Any updates? You could see about getting a pressure gauge and seeing what each caliper is getting.
Paul
:fr: FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
Generalee0527
Post by Generalee0527 »
I would check wheel bearing pre-load if you haven't already. Jack up each wheel and dee how hard or easy to spin.
68 Ranger. 302 Clevor w/ 3 on tree, soon to have front disc brakes.
