HI guys question 69 390 engine
should the pulley on the damper 3 bolt have lock washer?
I think that mine did not but should it?? and on the damper it self is there a lock washer ??
or just lock tight thank you very much
pulley lock washer
Re: pulley lock washer
The pulley on the damper should be attached using lock washers. The large damper bolt uses a large thick flat washer. That is the way my 360 with a 4 bolt is. Since my 302 and 351 Cleveland's are the same I am pretty sure the 3 bolt would be the same. The pulley bolts are nothing special but the damper bolt is fine thread. The washer is about 1/8 in thick so if you misplace it they kind of stand out on the bench. The damper gets a lot of vibration and if you are rebuilding the engine I would use a new one. I have had guys tell me that the use of grade 8 bolts for the pulleys is not recommended because the harder bolt is more prone to shear than a softer one. I don't know if that is true or not. I do use ARP for replacement of the big damper. But I have no problem using the stock one one a regular motor. I have never seen one that failed.
No Brain - No Pain
71 F250 Sport Custom Camper Special
71 Ranchero Squire
70 Ranchero GT (Red w/351C 4V
70 Ranchero GT (Black w/302+)
03 Kawasaki Vulcan 750
74 Kawasaki H2 750 (Widowmaker)
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
71 Ranchero Squire
75 Firebird 400
71 XKE FHC 4.2
04 XJ8 4.2
