1970 F250 4X4 Rebuild / Updating
- hfdco4
Re: 1970 F250 4X4 Rebuild / Updating
Some now that I am cleaning I did some measurements. It looks like getting the drive train put in the frame and the cab back on will give me the space to work and the wife's car will still fit!
Paul
FE390PC
1970 F250 4x4
2016 F150 4x4 2.7 ECO
Gone 1988, 1989 & 1991 Broncs
FE390PC
1970 F250 4x4
- hfdco4
So no work on the truck, but have been pretty busy getting house work done. I am still planning on the Drive Train install in the next couple of weeks.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
So, I was getting my parts together for installing the drivetrain. Came upon a big issue in that the two motor mounts are the same. They came in boxes with the correct part numbers, but I have two RH mounts and no LH mount.
So I went and ordered the correct one and will hopefully be picking it up Thursday.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Got the call today that my part is in at Autozone.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Picked up my correct motor mount. Pulled out the new clutch and found that it came with a Roller Pilot Bearing. Now I have to decide if I use the original Bronze Bushing or the new Roller Bearing? Trying to keep things moving I got the Bell Housing cleaned and painted.
Now I have to get the "Z" Bar and brackets cleaned up and ready for installation.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Got the clutch fork, z-bar engine mount, trans mount cross bar cleaned and painted. I found another z-bar that isn't worn so have to get that painted. I have to get my gantry crane lowered so it will fit out of the garage. Making progress with getting the drivetrain in the chassis finally.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Fordkid68
The bell-housing looks great!!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
My first truck,
^^Build Thread^^
- hfdco4
Started building the supports to set the bed on. Slow but forward progress.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Really got to work on the truck this weekend. Pulled the Trans and T-Case out from storage. Attached the new mounts to the T-Case. One thing I still have to locate is the Bell Housing bolts, but believe they are in the cabinet. I moved the engine over so I can pull it from the stand.
Now I have to pull out the Gantry Crane and get the Engine and Trans mated.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
I got the gantry crane pulled out and the engine is now hanging off of the engine stand. Now I need to pull the worn pilot bearing and install one of the new ones I have. I put the hardware for the Flywheel, Clutch and Trans into the Evapo Rust solution for cleaning. I also disassembled my old D44HD closed knuckle axle and parts are available if someone needs something short of the hubs.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Small update, clutch, bellowing and trans assembled to the engine. Pulled the bed from the frame and moved into the garage. Engine and trans installed in chassis now.
Next is to get the cab onto the chassis. Getting ready for winter work.
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
The cab is back on the frame finally. Now I have to get some rearranging done in the garage. I will post a bunch of pics tomorrow!
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- Fordkid68
Wow, you have been making superfast progress! Keep it up!
Adam
My first truck,
^^Build Thread^^
My first truck,
^^Build Thread^^
- hfdco4
Promised pics
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
- hfdco4
Paul
FE390PC
1970 F250 4x4
FE390PC
1970 F250 4x4
