has anyone ether built or bought an engine cradle for the 360? I'm about to pull mine with the C6 attached to clean up, re-gasket, replace freeze plugs and repaint.
pics would be great so I can get some ideas
thanks
engine cradle?
engine cradle?
Re: engine cradle?
Also need a source for good freeze plugs, American Made
Re: engine cradle?
I've always done that type of stuff on an engine stand. If you do come up with a cradle I'm interested to see your design, I've got a couple of engines I need to do something similar with for storage so I can scrap the vehicles they are in and clear up the yard.
Re: engine cradle?
As already mentioned, I would probably remove trans & place it on an engine stand..........
Summit has a BUNCH of engine cradles, but sadly, none for FE's
https://www.summitracing.com/int/search ... e%20cradle
But if you have a mig, all you need is some 1" x0.100" wall tube, and a couple chunks of flatbar. use the flatbar to make a plate that bolts to the block where the engine mounts were bolted up. Once the plates are made & bolted up to the block, using the 1" tube, build yourself a rectangular perimeter frame , and finally, add some 1" tube outriggers to tie the block plates to the perimeter frame......
ha! Just found these, GOOGLE IS YOUR FRIEND:)
https://www.centuryperformance.com/moto ... rd-fe.html
...and also found this, but the link in the thread it was in is DEAD (thread was from ~ 2009)
https://www.fordfe.com/engine-cradles-t70052.html
https://www.stumpysfabworks.com/store/c ... ducts.html
FORD FE Series Cradle $46.00
Ford FE 352/360/390/427/ 427 Side Oiler/ 428 Cradle
Comes with mounting hardware.
Will support engine or engine transmission together ..............$46.00
HD-P Caster Kit adds ....................$42.00
HD-PB (brake) Caster Kit adds $47.00
http://www.rcrmetalfab.com/ford-390-428 ... ies--.html
https://www.jegs.com/i/JEGS/555/80960/10002/-1
https://fordbarn.com/forum/showthread.php?t=43611
Re: engine cradle?
I found those after the first post because all I get find was one for cheby engines or SMF for some reason. Right now I have it on jack stands and its working.
Re: engine cradle?
I pulled mine and used an engine stand, but I left the transmission in the truck. I plan on building a cradle out of 2" square tubing and a piece of plate steal. With a mig welder it should be pretty simple. I will try to post pick after I have proven my design.
