Could this be the "needle in the haystack?" AC Heater Core
Uncle Bill
Post by Uncle Bill »
I have been trying to restore the factory HVAC system and one of the things (as we all have learned) is that the specific heater core to the AC system is long gone, har to find.
I have been trying to find the specific part number to that part and by searching the forums and doing some chasing.... this popped up on ebay..
https://www.ebay.com/itm/HVAC-Heater-Co ... :rk:1:pf:0
So.. I purchased it...ON THE HOPE.. this is it...AND..if it is.... THEY HAVE MORE!
So.. comments, advise? And..if anyone knows/has the correct part number including pre-fix.. that would be great!
Busboy
Re: Could this be the "needle in the haystack?" AC Heater Core
Post by Busboy »
I hope I'm wrong but I don't think that is for a truck with FACTORY air conditioning. My ford parts manual says the part number is C8TZ-184576-A. What makes me question the auto zone part is that FACTORY air conditioning was not available on a 67 model truck. It was in 68 up. The picture of that core looks like one for a truck just the standard heater box.
1967 F-100 4x4 custom cab.
Uncle Bill
I had read the post where the factory ac system was restored over a few pages...where the Rock Auto Part was listed.. but is not available. Somehow on ebay... that listing showed up and I compare to to the 399038... when compared via photos I decided to take the chance...
sargentrs
Post by sargentrs »
It looks like the right one. That's probably my AC rebuild thread you're referencing. http://www.fordification.com/forum/view ... 3&start=15 The original is 6"x6"x2" with the nipples sticking straight out on the bottom. That Ebay one looks like the Vista Pro I found on Rockauto although the nipples look a hair shorter. I only paid $25 for mine at the time but the markup doesn't surprise me given how hard to find they are.
Uncle Bill
Sargentrs;
I did go through your very thorough process to repair/preserve your A/C and heat system. Very, very well done.
In my case... I am trying to have replacement parts ready before my tech takes it apart so the the R & R can be completed very quickly. In the cab of the truck, it will look stock and work great. Under the hood will be fresh/modern components that will function better and be acceptable to look at.
I feel that the Autozone Heater Core could be the perfect part that we have not seen in a very long time. 4 month of searching and finally this appears to be it...and for that reason I wanted to share it here so that anyone who needs, or may need the factory AC Heater Core could find it... or store it until needed.
Great photo essay and write up on the AC/Heat system... thank you for sharing and documenting that process for all to see and under stand.
Bill
sargentrs
Post by sargentrs »
My pleasure, Uncle Bill! We're thinking along the same lines, modern parts/vintage look. 8) :thup:
Mach428
Post by Mach428 »
You should be able to take your original heater core to a good radiator shop and they can rebuild it like new. This is quite common. If you're looking for a quick turnaround, source the shop before disassembly. The upside is that you know it will fit.
Uncle Bill
Ok.. the core arrived and short of installing it...everything appears perfect.
Now.. I need advise on a part selection. What is the correct/factory ac expansion valve for a 72 f100 with Auto, 390, PS and FACTORY underdash AC?
Pics..part numbers...that would be great! Thank you.
sargentrs
Post by sargentrs »
scotty642
Post by scotty642 »
I know this is an old thread but I have some insight for those dealing with this problem.
the heater core for a straight heater box is exactly the same except for the tube configuration and location.
If you have the factory A/C heater core (presumably bad) and you either have a stock heater box core or buy a new one it is an easy fix.
first, for this method an aluminum replacement core likely will not work. much easier to solder one with copper brass tanks.
you will need a 5/8" rotabroach and (2) 5/8" brass freeze plugs.
using a blow torch, very carefully desolder and remove all brass tubes from both heater cores. then carefully clean them up very meticulously.
very carefully measure the hole locations in the old A/C heater core and layout center hole points on the new heater core.
very carefully press the brass freeze plugs into the original tube holes in the new heater core before drilling holes in the new locations.
leave the brass plugs hanging evenly out of the holes by approx 1/16 of an inch and carefully solder them in to seal.
using the rotabroach (extremely important to use a broach, drill bit will only destroy the tank) drill out the new holes for the A/C box inlet/outlet tubes.
insert the A/C box tubes and solder to seal.
now you have a good new A/C box heater core.
