neutral safety switch
Finished getting my steering column make together everything works,but now i have a another problem when i hooked the battery back up the motor starts to turn over and the key switch is off i disconnected the cable from the solnoid then it quits if i hook the cable back up it starts throwing sparks from the battery could it have something to do with the neutral safety switch? The reason i ask this when i had the steering column apart maybe i moved the position when i was messing around with the gear selector everything worked fine before i redid the column thanks
Re: neutral safety switch
The neutral switch doesn't have power unless the ignition switch is in the crank position.
1967 F-100 4x4 custom cab.
Was anything else tampered with while the column was done?
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
