strange carb set up. 1971 F100 AOD
Re: strange carb set up. 1971 F100 AOD
I connect mine to the "I" terminal on the starter solenoid.
Isn't there a terminal on the alternator ?
So if the engine stalls the choke won't keep opening.?
- BobbyFord
Stator terminal on the alt.
2300 should be a bolt on....
IS the Holley 2300 a direct bolt on?
I have a Weiand intake 4 barrel with a reducer to accept a 2 barrel. What I find strange is the carb was dirty, but the inside of the intake and runners were absolutely spotless. Not even a light coat of clean oil.
Honestly though, if you have a 4 BBL intake, just put a 4 barrel on it. Was it like this when you bought it? If so I would venture a guess that the seller had a nice carb on it and had a better use for it than letting it go with the truck
Holley 0-1850C has manual choke, vac secondaries and does 0-81570.
I do agree electric choke is nice. Holley 0-80570
- Ranchero50
That's tied to the positive side of the ignition coil and after the load resistor wire when the starter isn't running. Only getting a full 12v when the starter is turning. The wire T's off after the resistor section, one going to the coil, the other to the I side of the solenoid.sargentrs wrote:I connect mine to the "I" terminal on the starter solenoid.
I had a 2150 on a 71 pre smog 390 that someone tried. Truck did not run well. Can't give reason why but replaced it with a reman 2100 along with new heat tubes for the choke and it made all the difference.
Russ
71 F100 Ranger XLT, 390, C6, 2wd.
OMG! I've been doing it all wrong! Thanks, Jamie.Ranchero50 wrote:That's tied to the positive side of the ignition coil and after the load resistor wire when the starter isn't running. Only getting a full 12v when the starter is turning. The wire T's off after the resistor section, one going to the coil, the other to the I side of the solenoid.
DuckRyder wrote:2300 should be a bolt on....
Thanks for the options. Yes it had the 2 barrel on it when I got it. I opened the carb and rebuilt it yesterday. If its dont work I am gonna decide on a new Holley or reman Autolite
The carb bowl was dirty. Had a brown loose film in it. Its clean not with new parts.
Still puzzled why the outside of the carb was oily/dirty but the intake was spotless. Any reason?
thanks wyng I have read some people have success and some don't.wyngnut55 wrote:I had a 2150 on a 71 pre smog 390 that someone tried. Truck did not run well. Can't give reason why but replaced it with a reman 2100 along with new heat tubes for the choke and it made all the difference.
- Ranchero50
As said above, most likely swapped to sell. Personally I'd run the 2100 versus a Holley. Much simpler carb with no tuning issues and it'll do what you need for a stockish 302. Look for a 1.21" 2100 from a 390 if you want a little more kick. Heck, I'd probably put a 2bbl intake back on too. Just simpler with less adaptor leak problems.BayStYAt wrote:Still puzzled why the outside of the carb was oily/dirty but the intake was spotless. Any reason?
I rebuilt min yesterday. If it gives me issues I will hind a 2100 referb and go that route.Ranchero50 wrote:As said above, most likely swapped to sell. Personally I'd run the 2100 versus a Holley. Much simpler carb with no tuning issues and it'll do what you need for a stockish 302. Look for a 1.21" 2100 from a 390 if you want a little more kick. Heck, I'd probably put a 2bbl intake back on too. Just simpler with less adaptor leak problems.BayStYAt wrote:Still puzzled why the outside of the carb was oily/dirty but the intake was spotless. Any reason?
thnaks everyone. I will update once my intake is back from powder coat.
