427 fe casting numbers
My 427 does not have a C???? casting number on right side Not ground off What would this indicate?
kjm
kjm
Re: 427 fe casting numbers
What is the whole number ...Post pictures of all 4 sides of the block and the inside of the main web
I would like to clarify my request for info on my 427 side oiler
Location generally on right front side of block has no numbers i.e C5AE etc. and casting indicates nothing was ground off. (picture)
Left front side 13 dif
Left side casting date ??14 Picture
left front (driver side) 64 352
side rear either side nothing
Lifter chamber has 427 26 Picture
My picture files are too large will follow up
Needing comments on no model/engine casting number
thanks all
kjm
thanks all
kjm
Thanks for the response First there is no whole number the flatter area where the casting number should be never hadtnlprt wrote:What is the whole number ...Post pictures of all 4 sides of the block and the inside of the main web
a number. The surface of the metal is the same as the surrounding block and has obviously not been ground off. There are
no numbers or markings on the rear left or right side. Picture of date code did not come thru but all that is readible is the
??14.
427 and 26 on inside lifter gallery.
Has anyone seen a block with no numbers?
Last numbered pics as requested
How many motor mount holes on the sides of the block ...
And am I seeing a plug in that lifter galley?
Upon further review of your pictures
Should have 4 motor mount holes on either side
should also have provisions for a hydraulic cam
Looks like that is a 1969 or later block with the 2 dots under the first digit in the date code
Thanks for the reply
It has 4 motor mount holes per side. What and exactly where are the two
dots on the date?
dots on the date?
Look at the first digit on the date code
It has 2 dots below it ..They look to be attached to the digit but are not
The sand probably shifted when the block was cast making the digit mottled
The 2 dots represent the second decade in the production of the FE blocks
The FE was first produced in the late 50's and continued into the 70's
Well done
thank you
thank you
Final version
I love my FE's
427 foreground
428 rear right
390 rear left
427 foreground
428 rear right
390 rear left
you are certainly a Ford guy from the looks of things. Need more Ford guys
Any Cammers for sale?
Oh that looks nice! (Both the Cobra and the Truck burnout)
I believe I am going to move this to the engine forum because there is some good info here even though it is OT to original Ford trucks.
Do feel free to put some more pictures of that car in General or a new intro in the Welcome Mat.![Welcome :wel:](./images/smilies/icon_welcome.gif)
