Dash pad delete defroster vents!
Re: Dash pad delete defroster vents!
14...ouch. probably best to weld and grind and repaint. Unless anyone has a better solution.
For the front holes, 5/16" stainless hole covers from HD, the big box store, on the bolt isle in the pull out trays. For the top holes, 2" stainless sink hole covers from local plumbing store. Pics won't load, "file too large"
Here they are. This is what you can do for about $25. Both are stainless. The 2" hole covers are
Here's the 5/16 for the front holes. You could even paint all of them if you want.
