1970 F100 AM Radio replacement
spliff08069
Post by spliff08069 »
I want to replace my old AM unit and replace it with something that will fit in the factory dash and require no cutting or out of place installation kits. All I have been able to find is the Custom Auto Sound USA-230, USA-630 II, and the USA-740. I was wondering if anyone had installed one of these units and if they had any pictures after install. And of course your thoughts on the unit about appearance, quality, and use. Any help would be appreciated.
DuckRyder
Re: 1970 F100 AM Radio replacement
Post by DuckRyder »
RetroSound also makes one, see Bullitt74’s thread “Project 'Smokey' - '72 Ranger XLT” in Projects.
Idaho Chris
Post by Idaho Chris »
spliff08069 wrote:I want to replace my old AM unit and replace it with something that will fit in the factory dash and require no cutting or out of place installation kits. All I have been able to find is the Custom Auto Sound USA-230, USA-630 II, and the USA-740. I was wondering if anyone had installed one of these units and if they had any pictures after install. And of course your thoughts on the unit about appearance, quality, and use. Any help would be appreciated.
I am currently in the process off installing a RetroSound radio in my truck. I chose their Laguna radio which is AM/FM with an aux input. Their higher end radios have Bluetooth and USB input capabilities with a similar look. I also opted for the Ford AM radio screen protector option as you can see. Here is a pic showing the unit mounted in the bezel. It does mount in the truck in the stock opening without cutting or modification. The knobs are heavy metal (not the cheap plastic on some other radios) and feel good to the touch. I think they did a good job making it look period correct.
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
spliff08069
Wow thanks for the info. That is a good looking old school like unit.
DisneysPatB
Post by DisneysPatB »
I did the same thing. I liked the look of the unit. I got it with Bluetooth and also separate usb port and aux input which I have not installed yet.
https://fordification.com/forum/app.php ... /image/797
1970 F250 460 C6 - Project - Currently not running.
1999 Dodge Durango SLT 4 x 4 5.9 Magnum -not running.
1999 Toyota Corolla - Daily Driver.
https://fordification.com/forum/app.php ... y/album/43
MikeB
Post by MikeB »
This guy will rebuild your stock one to sound better and have all the updated blue tooth etc. https://www.joesclassiccarradio.com/contact.html
1972 F250 4x4 XLT stock but P.O. hacked
2010 F350 CC LB 4x4 stock
Idaho Chris
MikeB wrote:This guy will rebuild your stock one to sound better and have all the updated blue tooth etc. https://www.joesclassiccarradio.com/contact.html
I see he is also a RetroSound dealer!
-Chris
Mach428
Post by Mach428 »
Or you could install a factory Phillos AM-FM. That's what I did. I think I still have a few
Mach428
Post by Mach428 »
Or you could install a factory Philco AM-FM. That's what I did. I think I still have a few
BigAl47
Post by BigAl47 »
How much for Am-FM? Does it work or need repair
Thank You
Mach428
Post by Mach428 »
$100 plus actual shipping. I've had these for a long time and I do believe they all worked
Busboy
Post by Busboy »
I'd be interested in one too please.
1967 F-100 4x4 custom cab.
Mach428
Post by Mach428 »
I'll see what I have a post some pics hopefully tomorrow
1968f250429
Post by 1968f250429 »
I would possibly be interested in one of the factory am/fm radios if you have enough to go around . Let me know what the total price would be including shipping to zip 80233. Thanks
DisneysPatB
