1971 F-100 With Drum Brakes and Need a Distribution Block No Booster
Greetings,
I have a 1971 F-100 with drum brakes and need to replace the brake distribution block. It has a 302 with three on a tree and and is 2 wheel drive if that makes any difference. It does not have a booster. Does anyone have the part number of the brake distribution block I need or a diagram that lists it or a link?
Thanks,
Michael
Thanks,
Michael
Re: 1971 F-100 With Drum Brakes and Need a Distribution Block No Booster
Part number is C8TZ-2B257-D but good luck finding one. http://www.fordification.com/tech/propvalve101.htm Muscle Car Research sells rebuild kits.
Since its only a block and does not meter flow why not get one from a junk yard. Another plan woul be rouse a proportioning valve and to route new lines. Good luck
I hoped I could get a new one at a reasonable price. It's often cheaper to buy new than rebuild.sargentrs wrote:Part number is C8TZ-2B257-D but good luck finding one. http://www.fordification.com/tech/propvalve101.htm Muscle Car Research sells rebuild kits.
Thanks for the links. Got the old one off and partially cleaned. The part number on it is C8TA-2B257-M. Not sure if this makes any difference. The valve is not wanting to come out of the block, so I'm going to let it soak overnight. Looking at the instructions it should not be very hard to rebuild.
Might end up doing that if I can't get the valve out of the block. I have been able find most things with a few clicks and have them delivered. With a wife, 3 kids, and 2 dogs time to go pull parts at a junk yard is much better and more fun spent with the wife and/or kids.N2deep wrote:Since its only a block and does not meter flow why not get one from a junk yard. Another plan woul be rouse a proportioning valve and to route new lines. Good luck
![Smile :)](./images/smilies/icon_smile.gif)
Thanks,
Michael
I know where one is. What are you willing to pay for it?
1967 F-100 4x4 custom cab.
As little as I can!Busboy wrote:I know where one is. What are you willing to pay for it?
Missed a used one on eBay by three days for $20.00 bucks + shipping. Is this one rebuilt or in need of rebuilding? I've seen similar blocks NIB for $150.00 and used $20.00 to $80.00.
I'll be used. 50.00 plus shipping.
Is it a C8TA-2B257-M or C8TZ-2B257-D? I suspect either will work. Send me your paypal or other info in a PM.Busboy wrote:I'll be used. 50.00 plus shipping.
Thanks,
Michael
