Hey guys. Just joined. Going to be searching for a lot of random information.
Build is a 1979 F100(obviously) with a 2003 crown Vic front cradle, a flipped 8.8, 93 model 4.6 sohc and auto trans.
I had a 1993 grand marquis as a donor car and pulled the entire harness from the car. Also grabbed the steering column, cluster, dash harness, brake booster and set up, and a lot of smaller stuff.
I got the 8.8 all smoothed and set up on the rear leaf springs. Going to weld a few mounts on for the shocks in the next couple of weeks.
Have the front cradle almost done. Need to pull the engine back off of it to finish the fabrication.
Once I get the front cradle and rear shocks finished I will start to dive into wiring.
I know how to use a search bar and dig for info. Probably won’t post anything just mosey around and read for info.
I will post up info if I get it going in the right direction.
New member. Custom build looking for info.
- Gray035
- hdman90
Re: New member. Custom build looking for info.
from Pennsylvania!
- MadJoe
Welcome from MA!
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
from Massachusetts.
