What is this thing?
Gregtx
What is this thing?
Post by Gregtx »
Can anyone help me identify this seal? I recently fished this out of the filler neck of my radiator and I have absolutely no clue what this is, where it came from or how it got in there to begin with.
[image]604[/image]
[image]603[/image]
I figure since it was fished out of the top of the radiator, it must have entered through there as well unless the truck was run without a thermostat at some point. Maybe it's simply just some trash that found it's way into the radiator, possibly from a junkyard or something?
The truck is running fine otherwise, but I'd sure like to know if this looks like it might be something I should be concerned about or not. Obviously, I'm going to be flushing and cleaning my cooling system in the near future. I've got the oxalic acid crystals on order now.
Greg
1968 F-250 Camper Edition Special
F250 Build Thread
[image]561[/image] [image]600[/image]
Busboy
Re: What is this thing?
Post by Busboy »
Doesn't look familiar.
1967 F-100 4x4 custom cab.
colnago
Post by colnago »
Must be those muffler bearings that everyone talks about. Not an option for my '67, and I'm not sure how they got in the radiator. ... unless you had one @#$%&* of a backfire through the carb! :wink:
Joseph
DuckRyder
Post by DuckRyder »
What is it made out of...?
It looks vaguely like part of the shutoff valve on those funnels/tubes like you use for gear lube and such...
jzjames
Post by jzjames »
Looks like part of a hose or part of a spray nozzle on a hose. :D
tsherry
Post by tsherry »
>>Looks like part of a hose or part of a spray nozzle on a hose.>>
^^This.^^ I have one on my hose end sprayer. Identical. And, really, really old.
or, money.
Jacksdad
Post by Jacksdad »
Makes sense - someone used a hose to fill the radiator and that fell off.
Gregtx
Post by Gregtx »
The spray hose nozzle is likely the correct answer, and it makes total sense. Good knowing it’s not something more critical.
Thanks for the ideas, ya’ll!
Greg
F250 Build Thread
