Distributor recommendations
- Jacksdad
Slowly collecting the parts I'll need for my 351W swap, and I'm wondering what distributor/ignition everyone runs. My 352 has been using a Pertronix conversion with an Accel Supercoil for quite a few years, so I have no problem going that route again, but I want to make sure I thoroughly explore any other options (like Duraspark and HEI set ups) before I commit. Opinions, guys?
I don't want to get too spendy as my budget is pretty damned thin, so repurposed factory stuff would be my preference. I'll also be using an oval air cleaner which might cause clearance issues (although I have plenty of room for a spacer if necessary).
So, what is everyone running, and what did you need to make it work? I know I could google it but I'd rather hear real world experiences from you guys.
Re: Distributor recommendations
I've always ran the factory Ford Duraspark dizzy with an MSD 6AL box...never fails.
- Jacksdad
Any particular year or part number I should look for?
That would depend on roller cam or flat tappet cam. If memory serves, anything post 1975. If you are running a carburetor without all the vacuum add-ons, get one with a single vacuum advance diaphragm. I believe the roller cam Windsors, came in with the EEC-IV engine control module and they look like the 5.0 HO distributor. That setup can be used with Ford or Pro-M mass air fuel injection. At any rate, you don't have to use an MSD box, if you want to save the cash. With the std duraspark, you can use the factory Ford box and wiring. All from a '78 F100, F150, F250, Bronco or any full size Ford/Lincoln/Mercury car with a 351W.
- Jacksdad
Very much appreciated. I might head to the wrecking yard next weekend to see what I can find. It's a flat tappet cam, by the way.
Don't waste your time pulling the distributor or ignition module from a salvage car, unless they are immaculate and really cheap $. The only thing needed from the bone yard is the ignition wiring. You don't even need that, if you're using the MSD box. Here are a couple links to O'Reilly Auto Parts for the distributor and ignition module.
https://www.oreillyauto.com/detail/b/sp ... istributor
https://www.oreillyauto.com/detail/b/se ... ion+module
- Jacksdad
Awesome. I'll probably stick with the Duraspark module for now, but at that price, I might as well just go brand new. Thanks again ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
- colnago
I ran a Pertronix II on my 352 for years with no problems. When I rebuilt the block, I switched to a Duraspark system. I got all my stuff from RockAuto. I had to solder together a new mini-harness, but that was no biggie. Yes, I could have kept the Pertronix, but I'd been wanting to try Duraspark. I considered using an HEI, for the simplicity, but decided against it in the end.
I've recently turned into a "distributor tweaker," and I think the HEI and MSD are easier to tweak than the Duraspark. But if funds are tight, go with what you have. You can always swap it out later.
Joseph
Joseph
Another vote for Duraspark here. It's the first thing I do with all my vintage vehicles. It's a Ford, it wants a Ford ignition. Just my ![2 cents :2cents:](./images/smilies/icon_2cents.gif)
- Jacksdad
Thank you, guys. I guess that pretty much decides it. Duraspark it is ![Thumbs up :thup:](./images/smilies/icon_thumright.gif)
