What is this:
https://imgur.com/a/Hx511
Mounted on front of engine compartment, and has a few wires leading into it, and then some that look like they goto a thermostat or something mounted on top... The black cylinder.
The red wire, has pulled free of the connector and is not connected on it... I wonder what it does, do I need to fix it.
What's this thing?
Re: What's this thing?
That is the voltage regulator.
What does it to? The blade that connects wires doesn't seem to really plug into anything.... I took off the sheet metal dome portion, and there is nothing inside..
It controls the charging voltage unless the alternator has been replaced with something internally regulated.
That is a newer replacement voltage regulator, it is likely solid state so it should have a circuit board and some transistors and other electronic magic stuff in it...![Very Happy :D](./images/smilies/icon_biggrin.gif)
I replaced my old voltage regulator with an electronic one. The one you have contains points and the condenser on top acts as an electric noise suppressor ( may have some other function that I'm not aware of). It helps reduce electronic noise to your radio, that is if you kept the old analog radio.
I replaced the old system with new electronic upgrades, this includes replacing the points and condenser in your distributor cap with electronic ignition system. That is a relatively easy upgrade. Anyway, an upgrade to the voltage regulator isn't very expensive and I may be an option for you.
Would help us if we knew what year you are referring to.vossy wrote:What is this:
Take note that there are two different ways to wire the connector that attaches to the Voltage Regulator - the differences are based on whether your vehicle has idiot lights or if it has gauges. Hook them up the wrong way and you'll be making headaches for yourself.
- Ranchero50
Super ditto.
Wiring diagrams are in the main fordification site. Little difficult to trace since they are layout drawn versus function drawn but it can be done.
