1967-72 f100 parting out
Re: 1967-72 f100 parting out
Hi,
Just wondering if you might have a fan shroud for a 71 super cool rad?
Interested in driver and passenger fenders .price on 1972.
- colnago
I'm looking for a front driveshaft, approx. 33-1/2" from center of u-joint to the splined end.
Joseph
Joseph
dont have a front drive shaft,all are 2wd,will have to check on condition of front fenders,no shroud,
- colnago
Not the shaft for a 4x4. I think they're called coupling shafts. It's the short shaft from the tranny output shaft/yoke to the carrier bearing. I'm changing trannies on my 2WD, so I need a new coupling shaft.
Joseph
Joseph
busy right now now,next weekend i can see if i have the right size,i have a few,
Looking for a spindle assembly. 2WD with drums. Would be nice if I could get at least the hub and drum backing plate.
- urchinhead
I am looking for a good '70 grille shell and an original Carlite windshield; do you have any of these parts?
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
Im looking for a heater control valve cable. Its app 36-3/4 long.
- stonebystone
If you're still selling parts, I'm looking for the power steering column bracket that bolts to the outside firewall. I'm converting my '67 to Saginaw power steering. Thanks!
i only have manual steering brackets
I was wondering if you had some parts available, 1967 F100
Grill, grill upper panel, front bumper, radiator support, driver side fender, and hood latch rod.
thanks
thanks
wondering if you have driver side fender and lower fender cap, radiator support, driver light bezel? thanks
hi Im looking for small block perch part betwen crossmenber and engine support 302 351 winsor thank you
