4x4 hubs
- eggman918
Re: 4x4 hubs
I do not think so from what i have seen the 78-79 hubs have the lockout splines as a part of the hub and on the earlier style the lockout splines bolt to the hub with the rest of the lockout assy.
Steve
Re: 4x4 hubs
Ya I would use the complete rotor and hub if it will fit on the 78-79 spindle
- cstoyer
- Manny
Re: 4x4 hubs
Yeah nope... The spicer lockouts where specific to closed knuckle Dana 60's, and also the hd 44.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Re: 4x4 hubs
The 76,77 highboy has them with a 44HD
That's why I was thinking even if you had to use knuckles, spindles & outer axle shafts they would work.
Basically use a 1979 44 high pinion housing in a Highboy truck
