Is Gates 21045 the correct hose to fit a Duraspark II 460 in an Bump??
![Image](http://www.rockauto.com/info/64/21045-1_TOP_A__ra_p.jpg)
Originally the upper hose and thermostat were vertical with Gates 21034 and the small cap and points.
![Image](http://www.rockauto.com/info/64/21034-1_TOP_A__ra_p.jpg)
Replaced the thermostat housing with 4seasons 84859 horizontal thermostat housing,
![Image](http://www.rockauto.com/info/52/84859TOP__ra_p.jpg)
This was to clear the Duraspark II cap/rotor upgrade(pertronix flamethrower II coil/pickup replaced points components of the 460 distributor by current owner.)
Picked up Gates 20705
![Image](http://www.rockauto.com/info/64/20705-1_TOP_A__ra_p.jpg)
Thinking "460 in a '76 should work". Nope.
Angle is not quite right and, I'm guessing, the FE perches/mounts on the 460 have the engine a few inches higher than should be. This puts a nasty kink in the middle 90° bend.
Going to go snag a Gates 21045 and hopefully this will fit.
I've looked around on a few 385 series into Bump swaps and these details seem to be lacking... or is it my Search-Fu lacking?
Appreciate it if anyone could chime in with part numbers to confirm/deny. Thanks.
