New member
1browski
New member
Post by 1browski »
Hello, my name is Jim and new to the forum since January. Over the last couple years I have read lots of info from this forum and another. I have a 1970 f250 sc cs. I have had the truck about 20 years but it had been parked until last year when I finally put it on the road. This hasn't been a restoration, I've just been replacing and rebuilding parts.
Replaced the ruined original 360 with Short block 390 standard bore, machined the heads. That was 20 years ago then it sat. About 5 years ago I put in new auxiliary tank, sending unit, and filler neck hose. Year and a half ago I switched to aluminum intake and 4bbl holley. Registered it for the first time a year ago and since then fixing a little at a time.
Over the past year i have replaced MC, vacuum lines, front calipers, radius arm bushings, shocks, dimmer switch, door weather stripping, brake booster, power steering hoses, and tires. I don't think I have forgotten anything. I still have a few parts to replace before getting another batch. Post a pics next.
ok68crewcab
Re: New member
Post by ok68crewcab »
Welcome to the site!
2 Blessed 2 Be Stressed
1browski
Re: New member
Post by 1browski »
thank you and welcome to you as well. This pic is from a year ago but the truck still looks the same minus the camper hardware on the bed.
1970FordTK
Re: New member
Post by 1970FordTK »
Welcome from North Carolina. :thup:
lennyp
Re: New member
Post by lennyp »
:wel: from Massachusetts.
67mann
Re: New member
Post by 67mann »
:wel: from NY looks solid :thup:
Mancar1
Re: New member
Post by Mancar1 »
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
crazyhorse
Re: New member
Post by crazyhorse »
Mr Jim :wel: to the best site period. :fr:
Hope you like it here. :pray:
Pull up a chair and stay awhile. :woohoo:
Lone Ranger
Re: New member
Post by Lone Ranger »
:wel: from Michigan. Nice looking truck you got there.
Kyle
