I've found two related wiring schematics. This is the one that matches my wiring... http://www.fordification.com/tech/wi...350_master.jpg (This has the volt gauge rather than light.)
Nothing had been changed the 8+ years I've owned the truck except for replacement of the fuse link when I first bought it. (I haven't driven it more than 100 miles per year.) Early this summer, the truck would die after driven for a bit. My final diagnosis of the problem is charge voltage at 22-30 volts, which caused the wiring to get very hot and blew fuse link. With fuse out, I can remote start truck and it will run, with high voltage (not charging). I separated all fuse link connections with individual blade fuses. The only fuse to blow is the wire from the battery terminal of the alternator. This however doesn't help me understand what is causing the high voltage, I guess is the core of the problem.
The last several months I have been trying to sort this problem. I replaced fuse link with a blade fuse holder and even replaced entire fuse box with blade fuses. No change to problem. All grounding I have tested have tested good. Replaced voltage regulator, same. Tried a spare alternator, same, both bench tested good. Most recently, I replaced distributor, alternator, ignition switch, coil, cap, rotor, plug wires... resistor wire after it burned out from testing... all new.
Further, in the process of trying to eliminate possible bad wiring... removed all radio wiring, cut feed to roof lights, pulled all fuses... disconnected lighting wiring as best as I could track it down...(didn't spend a lot of time in lighting area) Disconnected all remaining switches (wipers cig lighter, etc...)... V regulator has ground wire cleanly bolted to it. I suspected a naked wire short, which is why I've removed all the shade tree radio wiring. The dash harness looked to be fully wrapped and intact (wipe off dust, looked new). I have unwrapped 90% of the wiring harness and there is no sign of damage to any of the wiring. I have traced and tested all related wiring.
The ribbon sheet on back of instrument cluster is melted between voltage gauge lines. I have been testing with cluster removed, my assumption is that removal will not affect circuit. I plan to manually rewire gauges after fixing problem as I don't plan to spend $80-100 for replacement that is also 46 years old. Optimally, I'd like to find, fix the problem and move on. If necessary, I'm willing to wire the charging system with new wire, I have what I'd need. Truck is nearing the end of it's life and I'm not willing to spend a lot of money on it. I already have too much invested to let it die. I have done countless web searches and can find NO results for this voltage range. Everything talks about 16 volts being high. When I have a problem, I have a problem...
