![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141019_120854.jpg)
Got the torch out again to clean off all of the brackets for the vic suspension. This included the anti sway bar, didn't want to bother with it since the final dream is to do the IRS swap.
The rear end is the one from the 05 Crown Vic which of course is the 8.8" and what I think to be a good option for Blue, X5 which is a 3.27 Trac Lok. Paired with the 3 speed c6 it should be a good mix of stoplight warrior and cruiser.
The plan is to use a factory style setup with the factory leaf on perches and a stock style shock mounts. To lower the rear I plan to start with flipping the front hangers and see where that gets me. I don't want to do an axle flip because like I said before I want Blue to end up with irs so I don't want to go cutting notches in her frame.
I wanted to get the bed off to make things easier to get to. Turns out Blue wasn't so willing to give up her bed. I had to grind the heads off of all but 2 of the bed bolts. I was alone on this portion of the project so I went and got the Massey.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150124_162321.jpg)
Little redneck ingenuity!
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150124_162308.jpg)
Farm truck? I think so. There is enough mud on the frame that it probably made the truck set lower that stock!
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150124_162317.jpg)
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150124_162343.jpg)
See that dirt!?!?
Slid the vic rear underneath the truck in front of the stock one just to take some eyeball measurements. I probably should mention at this time that I have two full sets of vic wheels. One set is off of a 98 p71 vic with the lower offset and the other is the 05 p71 set it the super high offset. This set you see here is the 98 which is the widest track.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150125_182502.jpg)
Doesn't look much wider than stock.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20150125_182510.jpg)
I would say for sure less than an inch wider on each side. Going to be close with the 98 rims.
While I had the tractor out i decided to throw the front clip on real quick to see how it was going to look. The first pics will have the high offset 05 rims and the second set will be with the low offset 98 rims.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141025_191009.jpg)
I hope the 98 rims will fit under the back. The 05 rims just seems lost deep inside the big fender.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141025_190948.jpg)
Drivers side with the 05 rims and a newer p71 center cap.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141102_150500.jpg)
Enter the 98 rims. Looks like the factory 77 did. I like this one better, just have to see if they will fit under the bed with that wide vic rear end.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141102_150636.jpg)
Put the old style p71 center caps on for these. Diggin' it!
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141102_150704.jpg)
I can't get over this awesome new stance. Can't wait to see how low she goes with the motor and trans in her.
![Image](http://i937.photobucket.com/albums/ad214/ENJOYOK/20141102_150714.jpg)
Well, this is where I set. Just waiting on some time to get to work on the rear end again. Will post some more as soon as I am able to get to work on her again. Thanks for letting me ramble to get caught up to present day!
