Nissangray
I have a '72 with a 429 going in (same block as 460) and an '05 CV
Look up 'F100 Crown Vic 460 Viking Build' (awesome build) he modifies the factory engine perches to use with the CV cross-member. I will be doing mine like this as well.
After much research, I decided on Bronco graveyard mounts (Extreme Duty 460 mounts) I like these better than the rubber block conversion mounts.
In the description it says its for 351/400....but (
http://www.fordification.com/tech/engine-perches.htm) you'll find that the engine perches are the same for the 70's trucks (mine was a 302, which is the same perch as 351/400)
That said, you could always find a set of 460 engine stands/perches, and use factory 460 mounts and modify the lower end to bolt to the CV cross member....but they are expensive.
Another option....not that I would use...are 460 mounts for the CV (
http://ritcheytrucksuspension.com/produ ... ic-2003-11)
So there are a few option out there for you. Probably more that I have not listed.
Hope this helps.
