Here is a short list I made while replacing the lights on my 1967 F100 with leds. I hope some of you find it usefull!
LITTLE TIP! To help get as much light out of my new bulbs as possible, I covered the inside of the housings behind the bulbs in reflective tape used on trailers.
Location X Needed bulbs.........................Part#.....(LED equivalent)
Headlights X2.........................................H6024 (7" round headlights) I used the Truk-lite LED headlights, but any 7" headlight with an H4 bulb will also work
Front signal/marker lights X2.......................1157 (1157 LED) Use an AMBER LED bulb, the more LEDs the better. Bulb height should be 1.80" or shorter
Brake/tail light X2....................................1157 (1157 LED) Use a RED LED bulb only! I originally bought white hoping they would be brighter, but they are not.
Reverse light X2......................................1156 (1156 LED) White LED
Interior light X1.......................................1003 (BA15S LED or #67 LED) I ended up building my own dome lights, and added some more along the headliner
Dash lights X7.........................................1895 (BA9 LED) I used 2 GREEN for the signals, 5 white for the rest of the gauges. Make sure they throw light in all directions or you'll have tiny spots
New lenses will help get the most from your new lights too, so if that's in your budget I recommend it. You will also need an LED flasher for the lights to blink properly.
If I remember anything else I'll add it!
1967 Bulb replacement guide for leds
- HIO Silver
Re: 1967 Bulb replacement guide for leds
2x... I use aluminum tape intended for sealing HVAC duct joints. Works great...
![Image](http://i49.tinypic.com/261zzmt.jpg)
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
- guhfluh
Add some good pictures!Lthlwpn wrote:Here is a short list I made while replacing the lights on my 1967 F100 with leds. I hope some of you find it usefull!
'67 F-250 Crew 2wd 300ci, T-170/RTS/TOD 4-speed overdrive
'96 Dodge Ram ECLB CTD
'99 Dodge Neon ACR 2dr - 10.64@130 (Sold)
'05 Infinity G35 Sedan
Thank you both for your great ideas and for gathering the information.
Cheers!
Cheers!
1967 F250 8Cyl. Custom Cab
Do your dash bulbs dim?
- shortbedCUSTOM
Can anyone tell me what flasher I would need for my '68?
-carlos
Are the lights on a 72 the same?
