new to site...and new to these trucks. '70 F100 SWB
need2xlr8
Post by need2xlr8 »
Hey guys. I just bought a '70 at Mecum in Kansas City over the weekend. The story from the seller (who is a dealer, so I take it with a grain of salt) is that he bought it from the 2nd owner and it was originally a Tennessee truck (stored in a barn, bla bla). It has original paint (buffed and polished) and interior, Ridler 18" wheels, lowered 2.5" (I don't know how yet, hopefully not hacked up). It is a 302 with a column shifted 3 speed. The only rust I saw on close inspection is in the driver side floor where the pan meets the firewall, tail gate (pretty bad on the inner panel), passenger fender 1/4" hole, and driver rear bed corner 1/2" hole.
Since it has been unmolested, aside from wheels and lowering, I do not plan on refinishing the body. It is a manually column shifted 3 speed with no pwr steering/brakes though, so any suggestions on making it safer and more fun to drive would be appreciated. Also, the dash pad and arm rests are trashed, so suggestions there would be great. (edit-I've been reading the interior forum on this, found good info there).
BTW, I'm 47, with reasonably good mechanical skills and tools. I've had many older and newer vehicles, and am currently restoring a '64 Chevy Biscayne 2 door. So I'd be confident in doing almost anything on the truck, aside from body work.
I will be reading a lot here in the next week. I didn't plan on buying any vehicles there, and therefore haven't done much research on these trucks yet, but I really liked it and couldn't pass it up.
Thanks guys
Shaun
1970 F100 Custom Cab Short Box 302 3spd original body panels and paint. 18" Ridler wheels
1970FordTK
Re: new to site...and new to these trucks. '70 F100 SWB
Post by 1970FordTK »
Welcome from North Carolina, hope you have fun with it. :D
EDVSU
Post by EDVSU »
Sweet ride! :thup:
Awesome condition and you can't go wrong with the 70' model. My personal favorite of the bunch. :D
:wel: from Texas.
- Martin Gza.
jimmy828
Post by jimmy828 »
:wel: from Asheville,NC. Nice find!
lennyp
Post by lennyp »
:wel: from Massachusetts.
need2xlr8
Post by need2xlr8 »
Thanks for the welcomes everyone.
It was delivered to town tonight and I drive it about 10 miles home. Runs pretty poorly, but made it nonetheless. It misses real bad, the belt is loose and worn, and screams, and the dash lights and temp gauge no worky.
Pretty typical for an auction flip. It has a Frankenstein plug wire set, so I'll pull and replace all of the ignition parts and see if that fixes the miss. Hopefully it's not a valve issue.
As a fun aside...I was poking around behind the seat, and found that a previous owner thought that beside the gas tank was a perfect place to Carry his road flares.
Mancar1
Post by Mancar1 »
Welcome aboard from Gerber, Ca.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
popeyes71
Post by popeyes71 »
:wel: from California! Like any new ride, there are always things to do to them, enjoy your new toy! :fr:
-Popeye-
1971 F-250 4x4 Highboy
AZf100
Post by AZf100 »
:wel: From Phoenix AZ, great looking truck, Sounds like you have some Maintenance ahead of you.
"I ain't as good as I once was But I'm as good once as I ever was"
https://photos.google.com/photo/AF1QipM ... mfKhMOFcFj
1971 F100 SWB 302 2WD (Work In Progress)
2010 F250 4X4 6.4 Power Stroke / lariat Black
2020 F150 4X4 3.5 Eco Boost / icon Silver
71StylesideF100
Post by 71StylesideF100 »
Nice lookin' truck, congrats.
One of these days I'm going to track down a chrome rear bumper.
71' F100 LWB Sport Custom 360 / Auto Boxwood Green
Wilfred of Ivanhoe
Post by Wilfred of Ivanhoe »
Cool story, and welcome! keep us updated please. Very cool!
1953 F100 (Waitint for attention)
1969 F100 LWB w/ 72 grille (Daily driver & work truck)
1969 F100 LWB Parts truck
1971 F100 SSWB 4x4 (Current Project)
2016 Jeep Wrangler Unlimited Sport (Actually the wife's)
tnab1970
Post by tnab1970 »
:wel: from Texas
need2xlr8
Post by need2xlr8 »
In the past week I have learned an awful lot on this site, Thanks guys.
And after poking around on the truck, I have learned a lot about it. Some good (the originality), some bad (the front suspension).
After finding that one spark plug was loose, and one was inoperable from the PO missing the hole the first time and getting so much oily, dirty crud on the tip it wouldn't fire, I cleaned all plugs, put them back in and changed the wires out. I thought 'That's it!" and I was hopeful it would run great...it did not. Concerned I had a bad cylinder, I ran a compression test. Thankfully that was good, and all holes were within a few lbs of each other. Hmm...
I did find the coolant temp sender wire was off, and after putting a new sender in for good measure, that works now. "Thank god something I did fixed something!"
I wanted to check the timing, and was a little concerned I had a bad distributor, so I called my brother in law to get my timing light I loaned to him...He tells me he can't find it... :doh: No "I'll buy you a new one" or "I'll keep looking", just "I don't have it anymore"... :x (In his defense, it was probably 5 years ago when he borrowed it).
Anyway, I started looking at the old, very old, coil. I got a replacement, and discovered some sketchy connections at the coil too. I replaced the coil and connectors. Not very optimistic this time, I fired it up. To my surprise, NO MORE MISS! I drove it about 10 miles, and although the carb stumbles, and the timing is probably off, the motor seems in good running condition.
I ordered a timing light from Amazon, and to my amazement, the local NAPA had a carb rebuild kit. So up next...the smell of gas in the garage, and lots of tiny springs, valves and gaskets on my bench.
Thanks again :fr:
Madman
Post by Madman »
:wel: Colorado!
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
