sound deadening material
Bill Ramsey
Re: sound deadening material
Post by Bill Ramsey »
Jacksdad wrote:
Bill Ramsey wrote:I used peel n seal on floors, firewall, back wall and ceiling. works great.
Bill - I know from personal experience that it gets a little toasty in Ramona. Any problems with the Peel & Seal not sticking to the roof when it gets hot?
Nope.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
Jacksdad
Post by Jacksdad »
Good enough for me - Peel & Seal it is. Thanks :thup:
Zorm
Post by Zorm »
anyone thought of using two layers of the "peel n seal" ? and when you did this, did any of you remove the tranny hump cover and do it separate?
sargentrs
Post by sargentrs »
I'm sure 2 layers of PnS would be double the soundproofing. I don't see that it would cause any issues. When I installed mine I just laid it right over the hump and then cut around the edge so I could remove the hump when I wanted to. Did the same thing with my EZ Cool insulation.
cdnwillyg
Post by cdnwillyg »
Just did my cab with Peal and Seal then the tight air bubble insulation and the carpet seems to do the job nicely. Haven't road tested yet but took away the tin can noise. :2cents: Threw some into the door cavity too.
Now does the carpet go under the firewall cover or over it??
1968 Mercury M250 Camper Special
FE-390,570CFM 4bbl, C6 Automatic, PS, PB front disk.
Stony Plain, Alberta, Canada
:drive:Willy
sargentrs
Post by sargentrs »
Under it.
cdnwillyg
Post by cdnwillyg »
Yeah that's what I thought too! Thanks Randy. :thup:
:drive:Willy
Lone Ranger
Post by Lone Ranger »
How's the tar stuff long term? What if it rusts underneath? I would imagine welding near the tar is out. Can you take it out if need be?
Kyle
cdnwillyg
Post by cdnwillyg »
I would assume that the floor is clean and rust free before one would apply it or adhesion maybe a problem. It will peel up but it is a task and that's only after a week in my case, once heat gets to it maybe tougher to get off. In both case where I have used it the under floor area has be under coated/ gravel guarded so rust would be way down the road...hopefully! The cost is so cheap which makes it a throw away if need be at $56 CDN. :D
:drive:Willy
