Red light cargo switch
nastys toys
Post by nastys toys »
I'm looking for the red light cargo switch that mounts in the dash. I just need the switch don't need the wiring or actual cargo light. Let me know if you have one thanks.
ICEMAN6166
Re: Red light cargo switch
Post by ICEMAN6166 »
mine in my 66 broke,the wire were brittle and pulled out of the switch
not sure if i can reattach them or not
this is the only one i found i can order
it is a direct replacement signal stat same as original the red knob is different but the factory one screws on in its place
http://www.ryderfleetproducts.com/signa ... -p-w71-102
but if anyone has a good used one from a parts truck i would rather give you the $
nastys toys
That's a great start to what I need. Now if I could only find a factory red knob I'll be in business. Would you want to part with your broken switch and knob?
chicof100
Post by chicof100 »
Hey Nasty,
here's my email address, robert.regina@verizon.net.
you can contact me there for a switch red knob and bezel.
1964 f100
292 yblock
1969 Ranger
Loving all ford vehicles
nastys toys
Chico f100 email sent
