Grill Inserts and Frame
urchinhead
Post by urchinhead »
Are the 1970/71/72 grills the same dimensions with different inserts, or are they each unique to that year? :?
1970 F100 Custom 2WD, SWB, 360 FE, np435
1964 Galaxie 500 Convertible, 390, Cruise-o-Matic
http://i171.photobucket.com/albums/u309 ... fa6562.jpg
HIO Silver
Re: Grill Inserts and Frame
Post by HIO Silver »
71 and 72 shells are the same and 71/72 inserts can be swapped.
The 70 shell is one-year only as are the inserts.
Attempt to put a 70 insert into a 71/72 shell and you will discover the mounting tabs do not align (and vice versa).
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
sargentrs
Post by sargentrs »
You can put 'em in there with a little "adjusting" of the tabs. They're not a perfect fit but will fill up the hole. The bottom sticks out about 3/4" at the bottom. Here's my '70 with '72 inserts. The top and bottom tabs line up but the '70 has 4 and the '72 has 6. Just leave the 2 side one's out.
