Changing Gear Ratios: What Would I Need?
- colnago
I have a '67 F250 Camper Special with a 4.10 or 4.11 rear end (sorry, I think it's a 4.11, but I don't remember for sure). What would I need to change it to 3.73 or 3.54? Just the ring and pinion? The whole rear diff? Would it be easier/cheaper to find a different rear end in a junk yard, and swap the whole thing?
Thanks,
Joseph
Thanks,
Joseph
Re: Changing Gear Ratios: What Would I Need?
You just need the ring and pinion gears. Might as well but new bearings and seals in while your at it. Do yourself a favor and find a rear end shop to set your gears, you'll be glad you did. Pull the chunk, take it to them and let them set it up correctly. I did mine and I'm not sure it's 100% right but I'm rolling the dice.
If you are going to learn how this is one of the easiest to do. In addition you will also need shims to set pinion depth, a new crush sleeve and a dial gauge to set backlash. There are rebuild kits that have all the bearings, shims, gaskets, seals and some Prussian blue to check gear mesh pattern.
Not with a Dana 60sargentrs wrote:You just need the ring and pinion gears
you will also need a new carrier.
I think it's a 3.90 and up take a different size .
There might be a shim to put under the ring gear to help some applications.
- colnago
Rats! That's what I was afraid of! Oh, well, better to find out now ...cep62 wrote:you will also need a new carrier.
I think it's a 3.90 and up take a different size.
Thanks,
Joseph
- Mancar1
I agree with Sargentrs on doing yourself a favor.
Since my shop and myself are not set up for it.
I am going to take mine to a rear end shop.
68 CS with the 4:10. I am going with 3:54.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Don't let that scare ya ,it's just the carrier not the whole case.colnago wrote:Rats! That's what I was afraid of!
I don't think they're all that expensive.
Or maybe just swap a used assembely ?
A gear change in the Dana 60 is more difficult than the 9 inch but totally doable. Spicer(Dana) has the instructions on their website. They say you need a bunch of specialized tools to properly set the pinion height in the housing. I found most of them in Ebay for a decent price. The thing I haven't got is the housing spreader. The spreader makes it easier to push the carrier in & out while shimming the carrier side to side. This shimming is needed to set gear engagement.
I did find this link if you really want to try yourself. It has a good explanation of the process & doesn't use the special tools.
http://dana60.com/gears.html
If common sense was really common, wouldn't everybody be using it?
- gregamorton
on dana 60s is 4.10 down and 4.56 up for swaps. So 3.54s and 3.73s will work in the 4.10 rear. I would not use any thing but a 3.54 if spending the money to change it all out.
1967 mercury F350 7.3 IDI ats turbo kit c6 gear vendor overdrive 3.73s rolling on 19.5s
1971 sport custom on 1979 f350 highboy frame 460 c6 np205 dana 60s 3.54s
1974 F100 baby blue & rust 240 3 speed 3.70s sitting on the ground!
1990 F250 extended cab FI460 e40d 3.55s daily driver
Possibly looking for my next bump right now!
cep62 wrote:Not with a Dana 60
I think ... I musta been thinkin bout Dana 44.gregamorton wrote:on dana 60s is 4.10 down and 4.56 up for swaps. So 3.54s and 3.73s will work in the 4.10 rear
Correct me if I'm wrong.
My bad. Didn't realize it wasn't a 9".cep62 wrote:Not with a Dana 60sargentrs wrote:You just need the ring and pinion gears
