Hail and well met !!!!
CharlaineC
Post by CharlaineC »
Hail and well met!!!!
My name is Charlaine I'm a 30 mumble mumble disabled and retired veteran from the Evergreen State of Washington. I live in Spokane county. I served three tours of duty in Iraq. I love to fly fish, Model rocketry. Hike, camp, hunt, build things, garden and many other hobbies. I recently bought an 1969 Ford f250 Camper Special 360 5.9 v8 with the Ford C6 transmission. The name given by her very first owner is Pearl. So like the tradition of the sea she will keep her name. (I don't want the bad JUJU!!!) I bought her knowing she had some issues. Many from the complete lack of common sense of the po or his stupidity not sure which. So far with the help of the Ford Truck Enthusiasts Forums as well as This forum I have already learned about what some of the issues I'm having are and how to fix them. The list of issues and what I've fixed so are listed below. I'm also going to be asking a lot of questions. As I work to restore her.
  • no oil( no really none zip nadda) the dang gum dran plug was loose and most leaked out. she took 5.5 quarts to fill to the right lvl
    tranny fluid near empty causing hard shifting
    cluster needed the ICR replaced.
    Fuel Gauge selector switch needed to be cleaned and re-lubed
    horns need to be replaced
    mirrors are mismatched
    headliner shot
    carb is out of whack
    suspect the need to replace timing chain
    rear view mirror was missing the arm
    exhaust manifolds need new gaskets and studs
    Wipers had never been replaced
    Plug wires where 45 years old and shot. Caused a fire as i was going to get new ones.
    Both Pcv valved where shot.
    Wiper res useless and in need for replacement.
    and a bunch of other little things.
Since getting her I have
  • Replaced the Icr
    touched up the gauges and needles as well as readied to add new faces to the gauges.
    Oil change and filter
    replaced main and aux fule lines and added inline filters.
    replaced pcv valves and elbow
    replaced the cluster bezel
    cleaned and relubed the tank gauge selector switch
    replaced some of the little missing parts
    found a second set of tires for summer
    replaced wireset and cap
    new wiper blades
    going to be matching the mirrors
    C6 tranny filter and gasket replaced
    all fuses replaced
    Newer arm rests
lennyp
Re: Hail and well met !!!!
Post by lennyp »
:wel: from Massachusetts.
1970FordTK
Post by 1970FordTK »
Welcome from North Carolina. :thup:
CharlaineC
where abouts in mass i moved from lowell mass to where i am now
lennyp
Post by lennyp »
I live in Fairhaven, close to New Bedford. Not far from the cape.
duaneo
Post by duaneo »
:wel: from the SF Bay area! It looks like you've already done a ton! When you're ready for a headliner, I recommend Dennis Carpenter, mostly because they have flat rate shipping, and the other sources out there want $100 to ship a $115 item. I haven't installed mine yet; that project is coming soon. :)
There are a lot of great folks here, and a TON of knowledge. Just be careful, if you have any OCD tendencies, you'll soon find yourself prepping for a frame-off restoration, shopping for a welder, paint gun, and compressor.
Keep us updated on your progress and don't forget the pictures!
Cheers,
Duane
1971 F100 - Ugly on the outside, but purty under the hood...
1968 Chevrolet Impala - Family car since 1970, My car since I was 16, in need of bodywork/paint, but otherwise straight.
2004 Mini Cooper S - Daily driver and grown up go-kart
iwhodat
Post by iwhodat »
:wel: from New Orleans and thank you for your service to the good ole' U.S.of A. :fr:
Stay thirsty my friends
duaneo
Post by duaneo »
From the mottled appearance, and the color inside the cab, it looks like she was originally (Pearl) white, and was painted yellow on the outside. Is that about right? She's definitely screaming "PAINT ME!" If you're painting at some point, what color are you thinking? How rusty are your cab mounts, floor pans, cab corners, and drip rails? :)
Cheers,
Duane
Madman
Post by Madman »
:wel: Colorado
2017 Ford Raptor
1970 F250 4x4
1975 Ford Bronco
sargentrs
Post by sargentrs »
:wel: from Georgia and thank you for your service! Bless her heart, she just needs someone like you to love her and care for her. :wink: Good luck and keep us posted!
jimmy828
Post by jimmy828 »
:wel: from Asheville NC
Mancar1
Post by Mancar1 »
Welcome aboard from Gerber, Ca.
From a Vet from another time. Thanks for your service.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
CharlaineC
Thank you everyone. It means so much to me. As for her original paint colour the vin plate states Pebble Beige, but i'm planning on having her painted to match my Pearl coloured purse. with pearled pink or pearled black two tone. the cab mounts i'm not sure about as of yet. I need to find them first. The drip channels are in good shape but need a good cleaning. my floor pans are in great shape.the cab corners seam to be in good shape.
i'm planning to replace the headliner and door trim panels with stained wood to match the cluster and soon to match the instruments. adding a hi mount for my cb radio and then plan installing one of the newer radios for her.
tsherry
Post by tsherry »
Welcome, from the Spokane Valley! Go to Pull and Save much? If not, you will find it a wealth of great parts for damned near nothing.
or, money.
Calfdemon
Post by Calfdemon »
:wel: from SoCal, and thanks for your service!!
-Rich
Current toys -
69 Ford F350 Crew Cab - 460 / C6 - http://i253.photobucket.com/albums/hh67 ... lqgskp.jpg
31 Ford Vicky - 1955 270 Red Ram Hemi / 4 speed - http://i253.photobucket.com/albums/hh67 ... bsibvn.jpg
Former toys -
67 Pontiac Firebird 400 convertible (sold 9/13) - http://i253.photobucket.com/albums/hh67 ... bird-1.jpg
67 Ford Fairlane GT - 390 / 4 speed (sold 7/15) - http://i253.photobucket.com/albums/hh67 ... c5hu8z.jpg
