bumper hitch on bumps?
blumule
Post by blumule »
bumper hitch? I was given a hitch and told it came off a 68 ford truck and just bolted to the bumper. i dont really see this working on my 69 as the mounting bracket wouldnt be flush on bottom of bumper. Did this require a special bumper? What kind of towing capacity could be expected? Ive never see one on these trucks.Was it a factory peice or aftermarket?
68RGR
Re: bumper hitch on bumps?
Post by 68RGR »
My '73 F100 has a bumper hitch. Well, it's not a receiver hitch and it mounts under the bumper.
Bill
68 F100 Ranger
73 F100 Ranger XLT
Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in garages. (Apologies to Kenneth Grahame.)
69Ford
Post by 69Ford »
My 69 has always had a bumper hitch. It had the optional step bumper. My new bumper from LMC truck is designed to have a trailer hitch installed right on the bumper. Maybe its just me but I don't trust this as much as the receiver style.
1969 Ford F100 Styleside standard cab 360 C6
duaneo
Post by duaneo »
I got rear-ended, and with no significant damage to the bumper, they sheared the bolts off that mounted it to the frame. I replaced the bolts, but it makes me wonder what the capacity of that hitch hanging off the bumper is. It seems like it can't be as much as the thicker receiver style hitches that mount directly to the frame.
Then again, my F100 is only a 3/4 ton truck with more worn out bits than fresh ones. What am I expecting to tow?
Cheers,
Duane
1971 F100 - Ugly on the outside, but purty under the hood...
1968 Chevrolet Impala - Family car since 1970, My car since I was 16, in need of bodywork/paint, but otherwise straight.
2004 Mini Cooper S - Daily driver and grown up go-kart
blumule
Post by blumule »
bolts to the frame? where? all I was given was the bracket with a 2 inch ball on it. The back side of hitch does have a bolt hole on it but how does it mount?
duaneo
Post by duaneo »
haha sorry. The bumper bolts to the frame. The hitch goes through my bumper with a nut on the bottom.
Sorry for the confusion.
Cheers,
Duane
Mancar1
Post by Mancar1 »
duaneo wrote:I got rear-ended, and with no significant damage to the bumper, they sheared the bolts off that mounted it to the frame. I replaced the bolts, but it makes me wonder what the capacity of that hitch hanging off the bumper is. It seems like it can't be as much as the thicker receiver style hitches that mount directly to the frame.
Cheers,
Duane
Your F100 is a 3/4 ton. Did you put your F100 body on a 3/4 ton undercarriage?
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
duaneo
Post by duaneo »
Mancar1 wrote: Your F100 is a 3/4 ton. Did you put your F100 body on a 3/4 ton undercarriage?
ahem. Let's just forget this little exchange, shall we? 1/2 ton, I meant to say 1/2 ton! this is what I get for perusing fordification late at night. :)
Cheers,
Duane
