Should POR-15 be thinned?
one of the first things i would do is read the ingredients of the thinner they sold you. if that is on the can . then i would check to see what else is made the same. as far as the mix doesn't the instruction say what the mix should be?
heep70
Post by heep70 »
You can email them. They respond quickly, but it is already the weekend. They are closed.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
DuckRyder
Post by DuckRyder »
I would strongly advise you not to spray the actual POR 15. The Blackcote works O.K. either way.
If you do chose to spray, it will need to be thinned, and be sure not to exceed the 20% maximum they specify.
Its extremely tricky to get the ratio right so that it sprays O.K. and dries properly.
I know it seems contrary to logic, but if you brush it on something like a frame, it will lay out smoothly if you apply it according to their instructions. Spend just enough on brushes to ensure the bristles don't fall out in the stuff.
Good Luck
BigBlue1971
Post by BigBlue1971 »
Well I took the advice of DuckRyder and painted it with a brush. I ruined 4 brushes but it went pretty well. Thanks for the help.
"Going to war without the French is like going deer hunting without your accordian."
Fordfool
re: Should POR-15 be thinned?
Post by Fordfool »
Whoah glad you didn't spray this stuff on! Painting is the way to go. I used foam throw away brushes on mine. I also cannot imagine thinning it. This stuff goes forever it seems. I bought 4 quarts to use and I have painted my whole frame and only used a little over a quart. That is with kicking the can over and spilling about a pint on the floor :lol: I have used 8 spray cans of semi-flat black Krylon though. Man, it looks great!
My Gallery
"Knowing is not enough, we must apply,willing is not enough, we must do" -Goethe
BigBlue1971
I was able to paint the whole frame with about a half quart. I hope that the stuff keeps for a few months so I can use the rest on my axles and suspension.
I got some on my hands and you're right, it doesn't come out! Oh well, battle scars!
460 crew
Post by 460 crew »
I sprayed my frame with no problems whatsoever along with the engine with a coat then sprayed their engine enamel too. Like stated above it needs to be thinned out just a bit to spray correctly. Just make sure you have proper ventilation and dressed with all your skin covered,and everything ready to clean up.
michaelbrainard
Post by michaelbrainard »
THe foam brushes work great!
