mustang tank/ drop hitch
Will a drop hitch still fit with the mustang fuel tank?
Re: mustang tank/ drop hitch
I believe it will. Going to find out myself..
Barry
Barry
Somene knows for sure . Maybe they will chim in soon. It would be nice to get the tank out of the cab and still be able to tow.
- HIO Silver
The scratch-built frame for the tank sandwiches the tank flange up against the frame rails. A bolt-on, frame mounted hitch will interfere with the tank and frame. A better option would be to use a 19-gallon, 72-80 lntl Scout tank from MTS. It's narrower and in held with straps. Some lite fabrication is required like a mounting points for the straps. Either with a Stang or Scout a crossmember has to be moved anyway so it's all in the scope of work.
I am thinking if you use the bumper mount bolts it should mount fine. Even if you sandwich the bumper brackets between it. It would require some modifications to the hitch.
Barry
Barry
