Replacing Vent Window Seals on '67 F250:
67FordTruckMan
Post by 67FordTruckMan »
Is there someone out there who might know how to replace/install a new set of vent window seals on a '67 F250?
I currently have a set of new "Precision" vent seals, but can not find suitable shoulder rivets to replace the 5 that
each vent window seal has. I'm reluctant to remove the 47 year old seals without first having the new shoulder rivets
in hand. Hence, without knowing the size (diameter, length) before hand, let alone locating the rivets, it has proved
difficult to move ahead with this project. The shoulder rivets will be installed into the division bar after it is removed
from the door, as you may know. Thanks
tac
Re: Replacing Vent Window Seals on '67 F250:
Post by tac »
I responded to this in another section.
LMC part 30-2740 Universal Vent Window Repair Kit may be what you want.
