cat 3126 4x4 any build ideas?
i have a 1971 camper special 2wd 360 with a 4 speed granny gear, dana 60 rear axle, i want front suspension ideas idk what axle to choose or what gear ratio would be good to use
Re: cat 3126 4x4 any build ideas?
and also is this even feasible
- Ranchero50
![Welcome :wel:](./images/smilies/icon_welcome.gif)
I think it's going to be pretty tight lengthwise. Add in it's 300lbs heavier than a 6bt. Then there's the whole SAE trans mount, what critter are you going to put behind it?
http://www.ciar.org/ttk/mbt/engine.cat.3126B.pdf
http://www.cumminsdieselspecs.com/12v.html
I went with a Cummins and it's a pretty tight fit. I had to raise the cab 1.5" for transmission clearance and really cram the radiator and intercooler into the radiator support so everything would fit half way decent. However, since it's such a popular engine there is a ton of support out there. I'm not too sure about parts or help for the big Cat.
IT is possible to do. You will certainly need to open up about half of the floorboard and firewall. The engine will sit 5-6" in to the firewall. Weight is a big issue, and Moog has some progressive rate springs, but those are the only ones I've found. Other option being custom front air bags. Your gearing will depend on tire size and what trans you use. Also, the 3126 is all electronic, which is good and bad. You can get some custom tuning, and marine injectors to make it an insane monster....if you want. The 3126 normally isn't a powerhouse, unless you get one from a fire truck or RV(highest hp ratings of 300-330hp).
A big diesel is a huge re-engineering project, and not just a swap. I'm about to get started on my swap pretty soon, and I've had the engine in my garage for 3 years.
67 F100, 300(Offy intake, Edelbrock 500, 274*/.518" lift cam, heddder, duraspark & Summit CD ign), 4spd, power steering swap, front disc and hydroboost.
08 VW R32
increase diesel fuel rate site:
http://www.freewebs.com/nevrenufhp/index.htm
08 VW R32
