3 Speed Trans leaking from shift arms
- cghstrojan08
Second day of drving my truck. Replaced the rear input shaft seal on my 3 speed trans and replaced the fluid which looked horrible before. Just got to work and noticed that there was a small puddle of fluid on the ground. Looked at the trans and where both shift arms go into the transmission are leaking. I would assume there is a seal around both of them but I can not find anyone that would have one. Any help?
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- BobbyFord
Re: 3 Speed Trans leaking from shift arms
Should be a National #340797 seal. Your local parts guy should be able to order them.
- cghstrojan08
Awesome, thanks! Ordered 2
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- blumule
I hope your aware this requires some disassembly of tranny. output shaft particularly.shifter forks also if my memory is correct,. others may chime in.
What type and how much fluid did you use? I wouldn't think they would leak enough to form a puddle. Isn't the Normal Fluid level below the shaft?
