Hood to Cowl Seal ?
BillT
Hood to Cowl Seal ?
Post by BillT »
Need a Hood to Cowl Seal (Long Rubber Weatherstrip) for my '69 F-350 and wondering where would be a good place to order one from?
Bill
Calfdemon
Re: Hood to Cowl Seal ?
Post by Calfdemon »
They are all pretty much the same and none of them fit well.. Maybe Dennis Carpenter will have a better one but they are all pretty much the same from what I have seen. I put one on from National Parts Depot and it came in a Dennis Carpenter bag, so I am pretty sure they are all made by the same vendor. Anyway, they do not fit well to the original mounting locations and I have heard this from everyone that has bought one. Basically what I ended up doing was only using a few of the clip locations to hold the seal in its general correct location and then used a silicone epoxy to attach it in place and make it completely waterproof.
-Rich
Current toys -
69 Ford F350 Crew Cab - 460 / C6 - http://i253.photobucket.com/albums/hh67 ... lqgskp.jpg
31 Ford Vicky - 1955 270 Red Ram Hemi / 4 speed - http://i253.photobucket.com/albums/hh67 ... bsibvn.jpg
Former toys -
67 Pontiac Firebird 400 convertible (sold 9/13) - http://i253.photobucket.com/albums/hh67 ... bird-1.jpg
67 Ford Fairlane GT - 390 / 4 speed (sold 7/15) - http://i253.photobucket.com/albums/hh67 ... c5hu8z.jpg
flyboy2610
Post by flyboy2610 »
I know I remember reading something about someone using a piece of door weatherstripping as a cowl seal, but the @#$%!*& search engine on here won't let me look for it! :x
They used the clip part to attach it to the cowl lip, and the seal part facing up, IIRC.
BillT
Post by BillT »
Appreciate the replies. I may just try a repro one and see how my luck goes. I found one at LMC for a pretty cheap price, but I'll also check with Dennis Carpenter.
They only list them for F-150 and 250's, but am I correct in saying that it will also fit my F-350 ?
Bill
Calfdemon
Post by Calfdemon »
Don't waste the extra money at Dennis Carpenter for that part as it does not fit just as well as the others. :lol: Just get it at LMC or NPD and then get yourself some clear marine silicone and have fun. As for the F100 and F250 fitting.. yes. The F350 cowl and hood are no different. It will fit (or not fit) as well as it does on the 100 and 250.
-Rich
Current toys -
Former toys -
BillT
Post by BillT »
OK, thanks.
Bill
hedz
Post by hedz »
and if your truck doesn't get to sleep in a garage when your not using it and you live in a area where it rains at least once a month, be prepared to change it 2 to 3 times a year. this particular weather stripping piece succumbs to dry rot faster than anything i have ever witnessed. faster than anything i have ever seen. the original 1972 windshield rubber on my truck holds up better than this 5 month old piece of rubber. the crappy g body rubber on my monte carlos i've owned held up better. i left one of the firestone tires that was recalled outside for years and is looking better. i'm on my 4th cowl stripping. if i were you i would find something other than the cowl stripping to use and make it work
Ranchero50
Post by Ranchero50 »
Definitely glue it on, mine has pine needle sticking out from behind it...
Stealth69
Post by Stealth69 »
I used a lmc one and glue it did not fit
'02 BMW 325xi
'69 Ford F250 C.S. Ranger 428 PI with gt 500 heads, racing c6, d60 3.73 limited slip, currently rat rod black (flat black) but going back factory Candy Apple Red / Wimbledon White
67mann
Post by 67mann »
They list for several yrs....this is one for a 68 http://cgfordparts.com/ufolder/showprod ... 971&t=5821
