Differences Between '67 and Later Door Locks
colnago
Post by colnago »
Okay, so I was working on te old girl, replacing the door locks so I could use a single key for doors and ignition, and I wanted to post a couple of pics between the original '67 locks and the new '68+ locks.
The first photo shows a side view. The'67 has the triangular tang, where the newer (replacement) has the squared-off tang. Not sure why they changed it. The new tumbler fit into the doors fine. :dk:
The second photo shows the real difference. The '67 uses a peg to engage the locking mechanism. The later lock has the plate with the hole. I had to switch these to make the new locks work in a '67 door. Other than that, it was a real simple swap.
Anyway, enjoy the photos, and I hope it helps someone.
Joseph
Calfdemon
Re: Differences Between '67 and Later Door Locks
Post by Calfdemon »
Strange.. Both my 69 and 72 use the peg. In fact, both sets of locks from both trucks look exactly like what you have in your 67. Are you sure that your "68" lock is stock and original? Every bump I have worked on in which I have taken the doors off of and taken the parts off of (about 8 or 9) have all had the peg and looked like your 67 locks.
-Rich
Current toys -
69 Ford F350 Crew Cab - 460 / C6 - http://i253.photobucket.com/albums/hh67 ... lqgskp.jpg
31 Ford Vicky - 1955 270 Red Ram Hemi / 4 speed - http://i253.photobucket.com/albums/hh67 ... bsibvn.jpg
Former toys -
67 Pontiac Firebird 400 convertible (sold 9/13) - http://i253.photobucket.com/albums/hh67 ... bird-1.jpg
67 Ford Fairlane GT - 390 / 4 speed (sold 7/15) - http://i253.photobucket.com/albums/hh67 ... c5hu8z.jpg
colnago
Post by colnago »
Hmmm ... How bizarre. The new tumblers had the flat plate with the hole, and a key that was identical to ours. It was definitely Ford. I got it from someone who gave me a '72 parts truck, and he worked for Ford, so I "assumed" that it was from/for his truck. Maybe you're right. Maybe it was a tumbler for something else, but happened to fit our bumps, but the arm was unique to something else.
Gad, I hate it when I assume ...
Thanks for the input/correction. Anyone else have experience with this?
Joseph
72BahamaBlue
Post by 72BahamaBlue »
I've had a few '70-'72 trucks. All had the rod type lever, but a NOS 67-72 lockset I bought had levers with the hole.
Aesop
Post by Aesop »
My 67 locks with the inside door handle, not a pull type lock by the window. I am sure I will have the same issue.
67 F250 4x4
